Which tube does my amp use? 845 or 211
I live in Austin, TX
you might be able to get some pizza outa this.
Sy?
I don't have a variable transformer. I do have five 120V to 100V stepdown transformers. I could plug several or all five of these in series to get the input voltage down. Then remove each one as I want to raise the input voltage. What do you think of this method?
i'd have to be present, to make any sort of call about this.
If I plug in all 5 120V to 100V transformers one after another, I will bring the voltage down to about 50V going in the amp.
Are you recommending using a variable transformer so that I can work with a lower voltage at first? Any lower input voltage will not give me an accurate reading.
Administrator
Joined 2004
Yes, I will definitely let you guys know the result.
I might have to treat him something better than pizza.
In case you guys are wondering, I will be using this amp for the TAD TL-1601a woofer in my TAD 4-way active system.
Actually I was referring to SY making you pizza, it's quite legendary, and I hope to get to Austin someday to hear his system and try some of that pizza.. Yeah, you'll owe him big time.. LOL :D
