long tailed pair - need more gain
Thread Tools
Old 9th April 2021, 04:28 AM   #61
directdriver is offline directdriver  United States
directdriver's Avatar
Originally Posted by TonyTecson View Post
would increasing the open loop gain in a williamson help? like instead of 12au7's the 6072's are used instead...
Like the Altec 1520T?
Old 9th April 2021, 04:42 AM   #62
TonyTecson is offline TonyTecson  Philippines
diyAudio Moderator Emeritus
TonyTecson's Avatar
i am not a fan of too many stages in an amp....
Old 9th April 2021, 10:24 AM   #63
It is still a Williamson circuit, if you minus the cathode follower stage. You asked if the 12AU7 can be replaced with a 12AY7 and the Altec 1520T gives an example that can be done, not suggesting you to copy the circuit.
I understand the purist standpoint of aversion to multi-stage circuits. I don't see a problem if two stages are direct coupled, which I treat it as a single unit as one stage is dependent on the other for bias. Personally, I'm not a purist. I like colorations as long as noise is not added. By the way, the Altec 1520T is great sounding amp that is transparent and accurate.
Old 9th April 2021, 10:36 AM   #64
TonyTecson's Avatar
the reason for my aversion is you end up with too many coupling caps...
but i can surmise that the grid are happier being driven by the cathode instead of the plate side where impedance are higher...
today there are other ways to do such things...
my theory is if the open loop of the williamson is higher by using the 12ay7 instead of the 12au7, then open loop will be higher and so addition of global feedback gives better margines....that is what i am interested in...
  Reply to this post
long tailed pair - need more gainHide this!Advertise here!
Thread Tools
Voltage Gain on Long Tailed Drivers lassoharp Tubes / Valves 7 24th May 2010 03:41 AM
Long tailed pair schematic questions martyh Tubes / Valves 17 28th January 2009 10:27 PM
LTPZen, Zen with long tailed pair input stage Allen Newby Pass Labs 18 28th January 2007 03:19 PM
DC coupled long tailed pairs sajti Tubes / Valves 10 23rd February 2005 07:16 PM
Long Tailed Pair Modification lubbie Solid State 31 11th May 2004 07:11 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
