6N3 Tube Preamp with DC-DC converter
Old 14th November 2018, 06:49 AM   #151
Hugh Jazz is offline Hugh Jazz  Taiwan
Hugh Jazz's Avatar
What value of current drain? A specific fet would be helpful : -) I've got some constant current diodes but I doubt I have the right value. Let me know which one you use and i'll order it.
There are many things to try, but for now I'm really focused on paralleling... I reckon 100R on the output of each will make load sharing work but will limit the benefits. I'm hoping to optimise the value of R.
Cheers!
Old 14th November 2018, 07:36 PM   #152
Koifarm is offline Koifarm  Netherlands
Koifarm's Avatar
Parallel 6n3 for headphone amp. But no low anode voltage(200v).
Old 14th November 2018, 09:34 PM   #153
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
Yes, as cathode followers with 200V B+ source they are fine.
Nothing in the universe is perfect. The ideal things are the ones that are most optimal. Optimization criteria, what matters. When I hear "No Compromise Design", I want to take a sledgehammer and test how impact-proof it is.
Old 14th November 2018, 09:48 PM   #154
Hugh Jazz's Avatar
And super E caps - nice :-) Thank you so much for sharing that!
Cheers!
Old Today, 10:14 AM   #155
Hugh Jazz's Avatar
Does anyone know if the two channels should measure roughly the same if they have the same power supply, same resistor values etc.? In other words, should there be a considerable difference between two channels of the same tube? I have two of these buffers, which is four channels, and for both buffers, the voltages across the resistors at the cathode are significantly different. For example, across the 470R connected to the cathode, the two left channels on each buffer both show 0.8V and the right channels are 0.2V and 0.35V. Is this a common problem with made in China tubes?
Cheers!
6N3 Tube Preamp with DC-DC converterHide this!Advertise here!
we can offer power module of DC/DC Converter & AC/DC Adapter auling Vendor's Bazaar 0 12th May 2009 04:48 AM
help whith a low voltage dc/dc converter schematic adi109cj Power Supplies 2 6th February 2008 01:12 PM
Suggestions for books/articles on building a DC to DC converter Corn-Picker Power Supplies 11 9th July 2005 07:42 PM
DC/DC converter to power tube amp? needtubes Tubes / Valves 2 24th June 2005 03:35 AM
DC-DC converter to get +-12V to feed the ouput opamps in DAC2000 Ryssen Digital Source 12 22nd January 2004 06:04 PM
