Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Tubes / Valves All about our sweet vacuum tubes :) Threads about Musical Instrument Amps of all kinds should be in the Instruments & Amps forum |
Thread Tools |
#11 |
Seems perfectly legible to me, and I think I'm picky. Thanks for posting it.
So..... no worry about B+ on a cold tube?
Take the Speaker Voltage Test! |
#12 |
diyAudio Moderator Emeritus
I'd agree- except for the two Greek letter oddities, it looks fine. I never worry about moderate voltages (i.e., <1kV or the Vbo(max), whichever is smaller), and I've never had an issue with tube life.
@Wavebourn, that's definitely Morgan's work. I even have a couple of the D3a that he tested.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is." |
#13 |
He writes really well.
!!!Warning!!! Single Ended Class-A-Holism is addictive!!! |
#14 |
I thought it was a good read, and the formatting ok. Probably an artifact of conversion from Word Perfect if that is what he uses. I previously used Ami Pro and when I converted to word about 12 yrs ago had to convert all of my documents to word which did not go well at all..
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine |
#15 |
If we can just get him to stop using Lotus 123...
#16 |
Can't you install OpenOffice on his computer?
#17 |
Hey, WordStar ruled.
#18 |
He only recently graduated from a quill and parchment.
#19 | |
Tubelab, I blow stuff up so that you don't have to. |
#20 |
I still use Ami Pro, I find all forms of MSW unintuitive and dreadfully confusing. Hear hear for the mighty quill and lovely vellum.
Bud
"You and I and every other thing are a dependent arising, empty of any inherent reality" Tsong Ko Pa |
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
New issue Mullard Tubes | rklosinski | Tubes / Valves | 8 | 1st February 2007 02:24 AM |
Lets do it all again: TL Sub. | Relax | Subwoofers | 61 | 19th July 2006 12:24 AM |
Here is My New Project, Lets see yours. | RWF | Subwoofers | 13 | 10th July 2006 05:45 PM |
Help me settle something | Lusso5 | Solid State | 5 | 25th October 2003 12:53 AM |
Let's build a great and proper (okay I will settle for good), OS DAC | alvaius | Digital Source | 48 | 8th November 2002 11:13 AM |
New To Site? | Need Help? |
