Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Tubes / Valves All about our sweet vacuum tubes :) Threads about Musical Instrument Amps of all kinds should be in the Instruments & Amps forum |
Thread Tools |
#101 |
I was concerned about the inrush on the filament as that's which seems to really shorten the life of lightbulbs. After reading about inrush current limiters being used on aircraft landing lights (which are very expensive) 10 yrs ago I tried it on a frequently used reg 100W bulb always turning it up and down with the slide pot switch. Lasted 7 yrs! Seemed I was always changing light bulbs before. I also noticed outside lights on photocells last for years as the ones I have slowly power the light up. I don't know about the off part or if down voltage speed matters. Reading the forms made me purchase a 10A variac last year and have used it power old tube amps and radios slowly that haven't been used for years.
This leads me to continue to use it to power up this equipment over a few minutes stopping at around 60v for the longest, then slowly up to 110-115 v as they were designed for 117V max. I try to stay at 111-112V for longer life? Is this good for filament? Maybe a good compromise? Is this better than inrush limiters which I intend to install. Will this short period of below normal cathode voltage hurt? What about the life of the variac? |
#102 |
Good question! I don't know... But it's quite possible they went thru a few rectifier tubes before I got them. I'll have to check to only 30s radio I have left.
Take the Speaker Voltage Test! |
#103 |
#104 | |
diyAudio Moderator Emeritus
As for the Bendix data, very interesting!
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is." |
#105 |
I've been using and building tube amps for 40 years, not all of them for audio. The only time you need a delayed turn on for B+ is with high power transmitter tubes. Well over 1000 volts, up to 25000VDC and/or amps, not milliamps, of plate current.
It's just doesn't have any affect on tube life in audio amps. Now, the thing that will made a difference is a soft turn on. Thermisters can help or series resistors in the AC primary that are bypassed by relay contacts after some delay both can limit the current surge in the heater circuit and allow the B+ to charge the filter caps slowly saving your rectifier. That is the thing that will help extend the life of your tubes, a slow easy turn on that keeps them from being shocked by sudden full voltage. BZ |
#106 | |
![]() Seriously, if the B+ is applied with the cathode already hot, then it might be a good idea to make sure the g1 voltage is stable and that the g2 and plate voltages come up smoothly with g2 below plate. Also good to think about the case where power is briefly interrupted and restored before the cathode has a chance to cool off. Smooth B+ ramp-up will cover both cases and is IMO all that is needed. Sure there are other reasons to sequence the B+ but IMO cathode stripping is not one of them. Last edited by Michael Koster; 24th June 2010 at 08:56 PM. |
#107 |
I have several types of tubes in my box, and ONLY the 12AT7 from BRIMAR makes a big Flash in the filament when turned on, almost like a lightbulb,and after a 2 or 3 seconds goes normal, maybe they used different material in the filament?
I think this is not good for the tube . Does someone has this experience with this Brimar tube? Silvino |
#108 |
Different people may say whatever, but tube manufacturers guarantee lifespan when operated in specs.
!!!Warning!!! Single Ended Class-A-Holism is addictive!!! |
#109 | |
I would like to know! Thanks |
#110 |
Jeez, what a lot of fluff.
If you have a tube amp and you expect your wife to turn it on, or off, you must have solid state rectification and no time buffer for the HT, along with one on off control and one volume control. If your wife is not involved, what difference does it make to a bunch of old farts, fooling around in their man cave, how many different switches must be thrown in the proper sequence? Back in the day, no one expected their tubes to last forever. Electronics repair shops were legion and all of them had stocks of tubes, due to their limited life time. The tube manufacturers didn't have to be concerned about extended lifetimes, especially for tubes in televisions. Tubes were a commodity and it was a profitable business model to replace them often. We don't live in those times, so why would anyone advocate treating tubes as they were treated, once upon a time, in a far gone land? AudioPrism got around the issue by adding a 50% extended primary winding as their first switch position step, with both heater and B+ coming on together, and this from the mind of a noted RF amplifier designer. I haven't noticed the tubes lasting any longer or shorter, than what I found with a Dynaco 70. They wear out, no matter what. So, just decide upon the matter by who has to use the amplifier and how complex an arrangement they are going to tolerate. Or is this the new popcorn corner? Bud
"You and I and every other thing are a dependent arising, empty of any inherent reality" Tsong Ko Pa |
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
New issue Mullard Tubes | rklosinski | Tubes / Valves | 8 | 1st February 2007 02:24 AM |
Lets do it all again: TL Sub. | Relax | Subwoofers | 61 | 19th July 2006 12:24 AM |
Here is My New Project, Lets see yours. | RWF | Subwoofers | 13 | 10th July 2006 05:45 PM |
Help me settle something | Lusso5 | Solid State | 5 | 25th October 2003 12:53 AM |
Let's build a great and proper (okay I will settle for good), OS DAC | alvaius | Digital Source | 48 | 8th November 2002 11:13 AM |
New To Site? | Need Help? |
