Hi all!
When i finis some my pre use tube 6h30, i like some tube DHT for pre.
So i like design HQ-DHT use tube 26-45-2A3 or 300B.
1. I use filament design by Rod Rod Coleman I was success it.
Thank Rod Rod Coleman
http://www.diyaudio.com/forums/tubes-valves/151421-26-pre-amp-44.html
My am li was not hum not noise.
2. And supply HV design by janneman
Thank Jannemen
http://www.linearaudio.nl/t-reg-1.htm
3. Cricuit HQ-DHT (I thank the consultants of Andrea)
I have some reference in the following websites:
26 Menu
kennedy
I see although the circuit i use incorrect data tube, but it sounds fascinating. I love it.
the sound is magic
Hi all, with experience and use tube 26 and tube 45, you can suggest or share my experiences and run modes of tube! thanks
Thank Jannemen
26 Menu
kennedy
the sound is magic
very nice Quanghao......
How is the sound....
the soud is very very like, i love it,!
Thank you helping by Andrea !
This is cricuit i use for filamentm design by Rod Coleman.
I spend 2 moths for some tube
I use for tube:
1. Tube 26 1.5V, 1.05 A
2. Tube 45 2.5 V 1.5A
3. Tube 6C4C 6.3V 1.05A.
4. Tube 300B 5V
the special it is no have noise and hum, i put may hand phone on the head tube 26, i can head some noise to speak!
I say it is wonderful, thank many many Rod Coleman!
Quanghao
I use for tube:
4. Tube 300B 5V
Quanghao
i use HV supply for hi voltage design by Jan Didden:
http://www.linearaudio.nl/t-reg-2.htm
maybe some group buy for filament pcb?
i think it depend your like this design and the sound when you use this design for all DHT.
we trust youi think it depend your like this design and the sound when you use this design for all DHT.
at last Rod
The group buy really needs the transistors as well as the PCB. Amp builders are having trouble getting the low-Vce Japanese transistors, and the MJ150xx are nowhere near as good.
Maybe it is time I offered a board & transistor kit, or maybe a basic module (no heatsink for easy shipping), tested.
Is there a need for something like this?
We know very well that Salas shunt sound good but the heat vs Rod ?
I need to power four 10Y .....
This circuit is unique advantages:
1. great for all kinds of DHT tube (EX. tube 26 - no noise)
2. Better than AC filament
3. Special design ever
disadvantages:
1. Components not available
2. Heat, heat 2 to 8-10W for a burning heart
- Tubes / Valves
- HQ-DHT (All tube DHT amli) 26-45-2A3
