12AX7 heater filament resistance
Old 24th August 2019, 08:48 PM   #31
6A3sUMMER is offline 6A3sUMMER  United States
anatech,
I love your text and picture of the Martian (Bugs Bunny cartoon?).
Sorry, back to old filaments, and other circuits. The amp was a stereo amp. Using a tube header, two 56k 2W resistors, and a 20 Ohm 5W resistor, I built a substitute for the top tube in the SRPP stages (or whichever circuit that took the output from the bottom tube plate, not the top tube cathode). It had formerly been a stacked 12AU7. The reason for the 20 Ohm 5W resistor was that the filament supply was 6.9V instead of 6.3V. There was a dropping resistor in series with the 6.9V to the filaments. With 1 filament now missing, I would have had to change the dropping resistor. But I wanted to be able to insert either the top 12AU7 or the substitute, and do so quickly, without re-wiring the dropping resistor. I actually liked the sound of the substitute better. Plus I did not need to elevate the filament supply anymore.
12AX7 heater filament resistanceHide this!Advertise here!
Very Basic 12AX7 Heater Question cfitzger Tubes / Valves 6 1st May 2014 03:05 PM
Is 6V DC too low for heater filament? Sunsun22 Tubes / Valves 8 29th December 2008 07:45 AM
5687 filament heater question dr._sleep Tubes / Valves 2 25th August 2005 03:45 AM
Troubl-shooting heater voltage for filament andy2 Tubes / Valves 12 10th January 2005 04:41 PM
grounding heater/filament center metebalci Tubes / Valves 6 27th March 2004 08:24 AM
Copyright ©1999-2019 diyAudio
