LED cathode bias - how to pick LED?
Old 26th December 2008, 05:44 PM   #11
dave slagle is offline dave slagle  United States
Just curious.... Why do they have to be LED's? has anybody played with other diode technologies? (shottky, hexfred...etc?)
dave
Old 26th December 2008, 05:45 PM   #12
Michael Koster is offline Michael Koster  United States
Michael Koster's Avatar
What about using the amber LED with a couple of schottky diodes?
That would get the voltage with the lowest Rdyn short of a battery.
As the OP said it's a spud amp, so I'm assuming it's an output stage
and low dynamic cathode resistance is king.
If it's a driver stage the Rdyn may be less important.
If it's a high-u spud amp using a 6C45pi for example, then you really
want low low cathode resistance as every ohm in the cathode gives
you ~50 ohms at the anode.
What tube is it?
Michael
Old 26th December 2008, 06:17 PM   #13
On Hiatus
SY's Avatar
dave
I've measured conventional silicon diodes and high speed versions (1N4007/UF4007) and saw numbers in the 4-5 ohm range. Putting enough of these in series to get the desired drop brings the impedance higher than the corresponding LEDs. I haven't tried Schottkys yet, but their whole raison d'etre is the low drop, so even more are needed in series.
If the Scottkys measure low, then Michael's suggestion or combining them with the amber LED is a good one. Otherwise, you can get a 4 ohm impedance with a couple of IR diodes in series.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 26th December 2008, 07:12 PM   #14
sharpi31 is offline sharpi31  United Kingdom
I will try the reds when they arrive and spend a while longer looking for a alternative with lower dynamic resistance :-)
Old 26th December 2008, 07:48 PM   #15
SY,
Would this be a good choice for an IR LED (2 in series required)?
OPE5594A
The forward voltage increases from 1.3V to 1.4V over 7.5mA to 90mA forward current.
My amp is the Hawthorne Spud kit so this is to bias the 6CL6 tube. Apparently the bias should be 2.5-3V so two of these IR LEDs puts me right in the middle of the recommended range.
Thanks for all the help so far.
Old 27th December 2008, 12:59 AM   #16
rman is offline rman  Canada
rman's Avatar
Hi.
How about a lm336 precision voltage reference
Old 27th December 2008, 02:13 AM   #17
On Hiatus
SY's Avatar
sharp, it looks superb at currents over 10mA. Resistance is deltaV/deltaI or about 1.1-1.2 ohms, if my squinting at the chart is correct. Two in series is 2.2-2.4 ohms which is as good as you'd ever want.
The other nice thing about this bias scheme is that, unlike capacitor bypasses, they don't go inductive at high frequencies.
Old 28th December 2008, 08:56 PM   #18
Originally posted by sharpi31
SY,
OPE5594A
These look great! Who stocks them?
Thanks,
Michael
Old 28th December 2008, 09:28 PM   #19
allied has them. (ope5594's)
In looking at all of the various data sheets out there I do not see any hard and fast rules WRT color and behavior.
here the Red and Yellow have the same characteristics.
Red and yellow with different characteristics
dave
Old 28th December 2008, 09:35 PM   #20
They're in the Allied catalog but non-stock.
RS online stocks them; guess it's time to sign up with RS...
Michael
LED cathode bias - how to pick LED?Hide this!Advertise here!
Changing grid leak bias preamp to cathode bias bereanbill Tubes / Valves 8 28th March 2009 06:26 PM
300B Cathode Feedback + Cathode Bias korneluk Tubes / Valves 13 7th January 2009 09:07 PM
Stray hum pickup *preamp* cathode R-bias vs. battery bias & 12AU7vs.5687 awedio Tubes / Valves 2 19th April 2008 02:30 AM
UL to triode mode conversion on cathode bias amp-different cathode resistors needed? bigwill Tubes / Valves 6 30th December 2007 01:37 AM
Amplifiers, how to pick transistors and bias them properly??? Duo Parts 4 27th June 2002 12:22 AM
Copyright ©1999-2019 diyAudio
