3.1 integrated possible?
Old 5th July 2008, 01:37 PM   #1
Brit01 is offline Brit01  United Kingdom
Default 3.1 integrated possible?
Has anyone built an all tube 3.1 integrated amp so I can hook up a center speaker for movies? Can I modify a stereo amp (K-502 for example) to add 3.1 channels from the dvd player?
Old 5th July 2008, 02:29 PM   #2
Tweeker is offline Tweeker  United States
You probably wont be able to add channels to an existing commercial stereo unit even if there was room, the power iron would likely be over strained.
The .1 is a sub channel. One approach would be a second stereo amp.
Be sure your foil hat has a good low impedance ground.
Old 5th July 2008, 02:45 PM   #3
Fuling is offline Fuling  Sweden
Not a 3.1 amp but a 2+2 ch tube power amp. Two HF channels with small output transformers and triode wired output tubes and
two bass channels with bigger iron and UL-connected outputs.
That amp served to drive a biamped speaker setup for a year or two before I rearranged the whole setup.
Old 5th July 2008, 03:16 PM   #4
The .1 sub is not a requirement for me. I should have excluded that one. Just 3 channels.
Haven't seen any kits for 3 channels. One option I guess could be to buy an assembled preamp ready for 3 or 5 channels and then use 3 tube monoblocks for the power stage to drive the front and center speakers?
But I'm exceeding my budget with this set.
Old 5th July 2008, 05:34 PM   #5
Eli Duttman is offline Eli Duttman  United States
An amp with 3 channels and 3 individual volume controls is not especially difficult. You may run afoul of "Catch 22", if your signal source can't produce, on its own, Left, Right, and Center "line" level signals.
Assuming the 3 I/P channels are available, how much power per channel are you going to need? Are you targeting the same amout of power in the center, "dialog", channel as you are targeting for the L/R channels.
BTW, think in terms of speakers that are reasonably efficient and that also exhibit a tube friendly "flat" impedance curve.
Eli D.
  Reply to this post
3.1 integrated possible?Hide this!Advertise here!
Integrated? rootbeer Class D 4 23rd December 2008 08:35 PM
WTB 211 or 845 integrated amp h00hbt Swap Meet 0 23rd March 2008 09:33 PM
what do you think of this integrated? graeme uk Tubes / Valves 4 19th May 2006 01:39 PM
Integrated Amp toman_9 Solid State 0 22nd January 2006 12:36 PM
JLH 10W integrated? JPablo Solid State 1 25th September 2001 01:41 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
