How to lower mains voltage using resistors
Old 10th June 2008, 11:36 PM   #1
johnm is offline johnm  United Kingdom
johnm's Avatar
Default How to lower mains voltage using resistors
Hi folks!
I want to drop the level of mains voltage supplied to a pre-amp from our measured 247V 50Hz AC wall outlet, to 220V, which the pre-amp is spec'd for.
I know this can be done by inserting resistors before the mains primary. My question is what is the formula for working this out please?
I have read it's also best to use four x 10W wire-wound resistors when the value of resistance is known, to increase power dissipation.
Any help would be much appreciated!
Thank you,
- John
Old 10th June 2008, 11:51 PM   #2
leadbelly is offline leadbelly  Canada
leadbelly's Avatar
Default Re: How to lower mains voltage using resistors
Are you sure you need to do this? Are you actually getting some adverse effect, or is it just a concern about specs?
No one wants advice - only corroboration.
John Steinbeck
Old 11th June 2008, 01:35 AM   #3
cerrem is offline cerrem  United States
cerrem's Avatar
Keep in mind that the source impedance, MAINS OUTLET, will no longer be low.... Assuming your load draw is CONSTANT or else the added resistance will create more problems...
Lets say for example you have a CONSTANT 400mA draw of current from your mains.... You need 27V drop....That would be roughly 67 ohms in resisitance on the HOT LEAD.... Nuetral and Ground should be left alone....
This 67 Ohms would produce roughly 10W of heat.... So use atleast x4 in power ratting.... Mount in box that is properly GROUNDED with outlet and plug mounted to box...
My recomendation is to use an auto transformer or VARIAC of some type to do this properly....
E= Voltage
E= IxR
W=(I^2) x R or W= ExI
Chris
Old 11th June 2008, 03:10 AM   #4
ak_47_boy is offline ak_47_boy  Canada
Voltage divider. Extremely inefficient.
Old 11th June 2008, 03:26 AM   #5
Boris_The_Blade is offline Boris_The_Blade  United States
Boris_The_Blade's Avatar
Get a Variac
Old 11th June 2008, 04:32 AM   #6
HollowState is offline HollowState  United States
HollowState's Avatar
You could try bucking the primary with a 24 volt transformer, but sometimes going more then about 5% gets hairy and may pull a lot of current. You just have to try it and see.
In case you aren't sure what bucking is, it's putting the secondary of a low voltage transformer (of suitable current) in series with the main transformer's primary. Then connecting the LV transformer's primary to the line out of phase. (Or connect the secondary out of phase, doesn't matter) There's a 50% chance of getting it right the first time. One way will buck, the other will boost.
Victor
"At the heart of quantum mechanics is a rule that sometimes governs politicians or CEOs - as long as no one is watching, anything goes." ~ Lawrence Krauss
Old 11th June 2008, 10:31 PM   #7
johnm's Avatar
Thanks for all the replies guys
Unfortunately a variac is out of the question at present - I don't have the funds available for now.
The transformer(s) in question are from a Ming Da MC-7R pre-amp which I imported three years back. It was a European model and contains the 220V transformer, rather than the 240V item which the proper UK version comes with. I am now using the transformers and chassis for a new project.
If poss. I'd like to go the resistor route at present unless I'm OK using a 220V tranny on a 247V line? Is it OK (safe!) to connect the primaries to the 247V mains, and then using a meter connect the probs to the 300V secondary, and CT to measure the secondary voltage?
Thanks,
- John
Old 11th June 2008, 10:43 PM   #8
Wavebourn is offline Wavebourn  United States
Anatoliy Lisovskiy
Wavebourn's Avatar
It is Ok if it does not hum more than on 220V and is not too hot.
!!!Warning!!!
Single Ended Class-A-Holism is addictive!!!
Old 11th June 2008, 11:21 PM   #9
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
Hi folks!
Thank you,
- John
In my valve pre amp I used a transformer to drop mains to 12VAC. This was used for the heater cct but also went into a reversed transformer of 18VAC to mains which gave about 180VAC for the HT for the valves.
This is certainly safer than messing directly with mains voltages.
It also isolates the cct from the mains.
2020 versions of PCBCAD51, PCBCAD360 and PCBCAD720 out now >>> https://www.murtonpikesystems.co.uk
Old 11th June 2008, 11:35 PM   #10
wakibaki is offline wakibaki  United Kingdom
Banned
Mains voltage varies anyway.
Well designed equipment will operate over a range of voltages.
The difference between the nominal voltages is ~10%.
This probably falls within the range which the equipment will tolerate, but when the voltage is at its highest the stress is greatest and the temperature highest. This can result in accelerated failure.
If you are drawing close to the rated current then naturally the rated power may be exceeded, but lower currents will keep this and the temperature within limits, in which case breakdown of the insulation is unlikely.
Obviously you are operating the equipment out of spec, and this constitutes an unquantified risk, for which you are responsible. The risk of catastrophic failure is increased although probably remains very small. It is up to you to decide whether the risk is acceptable. Such a risk would be considered unacceptable in a professional context.
w
How to lower mains voltage using resistorsHide this!Advertise here!
Lower voltage LM386? DonFlamenco Chip Amps 1 6th September 2006 10:56 PM
Should I use high voltage value zeners or multiple lower voltage zeners in series? jarthel Parts 7 30th May 2006 04:56 PM
resistors of a lower power rating 9am53 Tubes / Valves 2 15th May 2005 04:06 AM
Zen with lower voltage? DorcyDuck Pass Labs 9 20th April 2004 05:02 PM
How to lower supply voltage avenger Chip Amps 18 24th November 2003 07:20 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
