The migration to our new platform will be happening today at 11AM GMT/UTC, Wednesday 8th December 2021. See this time in your city. The site will be down for 24-48 hours while we perform the migration. Read more here.
Power Trans question
Thread Tools
Old 21st March 2008, 08:40 AM   #1
diaz028 is offline diaz028  Canada
Default Power Trans question
I have a 380V PT. Using a bridge rectifier and a capacitor filter, the voltage jumps to about 530Vdc (loaded).
The original design required a 350V PT and gave about 470Vdc (loaded).
Question, can I use a zener between the bridge rectifier and the first filter cap to reduce the DC voltage?
Thanks.
-D
Old 21st March 2008, 08:52 AM   #2
Geek is offline Geek
Geek's Avatar
Use a C-R-C filter, that'll take care of it
Since the voltage is 530V loaded, you know your current drain. You need to drop it by 60 volts. Therefore your resistor value will be:
R = E/I
or
R(ohms) = 60V/current draw in amps.
The resistor should be rated at least:
P = E*I
or
P(watts) = 60V*current draw in amps
Cheers!
Old 21st March 2008, 12:14 PM   #3
Tweeker is offline Tweeker  United States
You may want to use a resistor rated at least twice Pd.
Be sure your foil hat has a good low impedance ground.
Old 21st March 2008, 04:33 PM   #4
RM529 is offline RM529  United States
No, you won't be able to place a zener diode like that. Do exactly as recommended by Geek and get a choke input instead of capacitor input.
Old 21st March 2008, 04:46 PM   #5
Eli Duttman is offline Eli Duttman  United States
Default Re: Power Trans question
Thanks.
-D
As the other posters indicated, a Zener diode is a BAD idea.
You can achieve your purpose, without generating lots of waste heat. Use CLC filtration. A 10 H. choke and a substantial reservoir (2nd) cap. are needed. Start with 1.5 muF in the 1st filter position and load the PSU down. Increase the amount of capacitance in the 1st position, until the rail voltage comes in right.
Another technique for shedding a few Volts is the use of a hybrid bridge rectifier. The forward drop in the vacuum half of the bridge helps, in this particular situation.
Eli D.
Old 22nd March 2008, 09:24 PM   #6
What resistor value should I use in this schem?
-D
Old 22nd March 2008, 10:31 PM   #7
R = E/I
or
P = E*I
or
Cheers!
Like the schematic I posted?
Old 26th March 2008, 04:59 PM   #8
nafanja is offline nafanja  Ukraine
Default Hello
You can use LC filter.
LC filter more putdown the Voltage than CLC
LC have soft sound. (have a soft curent waveform and minimal harmonics) sounds better than CLC or CRC,
but if You make stabilisation it's will be better.
Parralel stab better.But this recomandation if you like clear sound and you closed acoustic system.
Many people like painting sound and stabing is cleared sound that bad for them.
Shippment: $:Europe: 1,2 x (16+2,45 x Weight(kg))
N. Amerika & Asia: 1,2 x (10 +4,9 x Weight(kg))
Old 26th March 2008, 08:39 PM   #9
Geek's Avatar
-D
We're still missing a number for the equation - what's your total current draw?
For now, place a 10 ohm resistor there and measure the voltage across it. This will tell us how much current the circuit wants. Then we can determine the resistor to drop your voltage
You could also try rearranging the circuit as mentioned before, to a L-C (though that may drop it too much).
Cheers!
Old 26th March 2008, 08:58 PM   #10
Ty_Bower is offline Ty_Bower  United States
Ty_Bower's Avatar
Here's an idea that might be worth trying:
http://www.diyaudio.com/forums/showt...08#post1281708
  Reply to this post
Power Trans questionHide this!Advertise here!
Thread Tools
Question regarding to output power trans hc167 Solid State 14 28th June 2008 10:41 AM
Power Trans, 45V-0-45V pistoljoe Swap Meet 1 15th April 2008 11:39 AM
Help on 300B power trans... sklimek Tubes / Valves 2 15th July 2005 11:24 PM
Power Trans Question cominup Parts 8 9th June 2005 09:06 PM
Power Trans. Sockets or not mashaffer Solid State 5 15th May 2005 04:18 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
