Hello,
I searched forums and didn't find any answers.
Would a low AC voltage say 100 to 105 volts be a problem for an original good sounding Grommes 24pg amplifier.
And no the house current is OK at close to 120.
Just wondered if using a variac to run an original good sounding amp a little shy of 117 would be easier on transformers etc.
What does everyone think?
Thanks, Watsi2
Thanks, Watsi2
variac soft start and low voltage operation
I am currently using a variac to provide a very soft start. And I noticed that the tone seems nicer at about 100, to 105 volts max.
Also when I shut it down, I slowly drop voltage and my little Grommes will produce nice tone down to 50 volts or less.
My question to the group.s. Is there any reason that I should not use these methods of operation? I can't think of any with my very limited knowledge.
The more I read and study tube audio books it seems that only a small amount of learning occurs. I will buy and repair some gear, and build amplifiers soon.
I have been reading posts on this Forum for sometime and find it very informative!
Cheers
Cheers
Dropping B+ isn't a problem, but dropping filament voltage can cause some.
but.. 105v.. <10%... good enough. You could wire a 12v transformer as a buck deal to drop the mains from 120 to 108, if you want, and free up the variac. If the sound is related to B+ change, = shift in op point, and not fil change, you could always modify the PS some.
