6V6 line preamp
6V6 line preamp
Old 30th January 2019, 03:50 PM   #3491
bubba177 is offline bubba177  United States
Could someone tell me what the minimum voltage on the coupling capacitors would be??? Thanks bubba177
Old 30th January 2019, 04:16 PM   #3492
merlin el mago is offline merlin el mago  Europe
merlin el mago's Avatar
Normally voltage rating same as PSU B+
Old 17th February 2019, 09:53 AM   #3493
I have a transformer with two 18 volt secondaries. is this too much voltage for the filament constant current circuit? Thanks for any help
Old 17th February 2019, 11:13 AM   #3494
6L6 is offline 6L6  United States
6L6's Avatar
6V6 line preamp
bubba177 - does it have dual primaries? You could wire it for 240v, and get 1/2 the voltage on the secondaries, and that might work... But I'd still put a decent size heatsink on the LM317's, as it still has a lot of voltage to regulate away (by turning it into heat)
Old 17th February 2019, 03:30 PM   #3495
It does but trannie also has b+ and rectifier. So that won't work. Right now i'm using lm7812 fixed with 12v6. Was trying to be able to use new tung sol 6v6 using the 18v filaments. Guess adding a small trannie is best option what do you think?
Old 17th February 2019, 03:34 PM   #3496
6L6's Avatar
6V6 line preamp
Wire heaters in series and use one filament regulator. Easy.
Old 17th February 2019, 03:39 PM   #3497
one secondary was only designed to power 3 12ax7's which is about 45ma I think, which is one 6v6. i have to use both secondaries one per tube
Old 17th February 2019, 03:40 PM   #3498
6L6's Avatar
6V6 line preamp
With that much drop you'll need a Big heatsink on the regulators.
Old 17th February 2019, 03:46 PM   #3499
how about putting regs in parallel and then powering two 6v6 in series?
Old 22nd February 2019, 03:59 AM   #3500
Anchan is offline Anchan  United States
I know that it has been stated that the input Z of the amp receiving the signal from this preamp should be 15-20k, but how strict is that?
Can I run the 6v6 gain version, with 3uF output caps, 2ft max cabling, into the unbuffered version of this ncore amp with input Z of 5.3k ohms?
https://www.hypex.nl/img/upload/doc/...tasheet_R8.pdf
RC calculation says the roll-off is 10hz, and I believe the gain version output Z is 1.5k, so should be sufficient? What would be the negative repercussions if any?
If not enought juice, can I run two 6v6s in parallel?
6V6 line preampHide this!Advertise here!
Help me design my DAC/Line Preamp. kuroguy Tubes / Valves 7 2nd April 2009 08:31 PM
preamp line ctt richwalters Tubes / Valves 1 7th March 2008 04:34 PM
Preamp for Line In and Mic blur Instruments and Amps 1 4th January 2007 04:02 PM
Line stage preamp, based on SY's "Heretical Unity gain line stage" Danko Tubes / Valves 23 18th July 2005 04:07 AM
Line preamp for 2A3 amp Petman Tubes / Valves 0 24th May 2002 03:11 PM
Copyright ©1999-2019 diyAudio
