6V6 line preamp
6V6 line preamp
Old 14th September 2018, 02:37 PM   #3381
Anchan is offline Anchan  United States
Ok, is 200V ok on those FT-3 input caps, or do I need to go 600V. Size is a bit of a concern.
Prices not bad on them on eBay.
Originally Posted by skrstic View Post
FT-3 is Russian teflon capacitor. 180R/5W , 470/2W and 5K/10W (2x10k/5W).
I borrowed from a friend a 4.7uF Mundorg capacitor. Is it OK to try?
PS. Hum is gone. Bad ground wiring.
Old 14th September 2018, 03:36 PM   #3382
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
6V6 line preamp
Theoretically 200V is alright for that input position in the buffer version (cathode follower) but prefer a higher rating if you can because the thicker film material inside achieves better spec and reliability.
Old 14th September 2018, 03:45 PM   #3383
Salas's Avatar
6V6 line preamp
Good news about solving your hum. If you mean 4u7 in the output position, that's also legit. When you want same bass and upper bass "feel" between systems calculate the RC time (translates to frequency) of your output cap and next stage's input load (each system's poweramp) to be roughly comparable in phase shift.
RC High-pass Filter Design Tool
Old 14th September 2018, 03:49 PM   #3384
Salas's Avatar
6V6 line preamp
Originally Posted by nikosokey View Post
Two words and from me. Ever since I finished this construction never came down from my audio system....
Nikos, nice video presentation, once again congratulations on your first but thorough tube preamp build.
Old 17th September 2018, 12:37 PM   #3385
skrstic is offline skrstic  Serbia
A friend suggested me the following changes ...
Is it OK to try it?
Old 17th September 2018, 01:14 PM   #3386
IDM is offline IDM  United Kingdom
I think that design change would put the grid at at more than -200v relative to the cathode. With rather tragic consequences.
Built as is, the cathode follower version is quite stunning. I was unsure of the extra signal path capacitor, but can honestly say it is not an issue.
Just build as Salas Shows, you wont be disappointed
Cheers
Ian
Old 17th September 2018, 03:25 PM   #3387
Salas's Avatar
6V6 line preamp
@skrstic
You could use a 50k log volume pot or less, if your signal sources are at ease with such values, so to achieve wider bandwidth if you like. But I wouldn't recommend any other area for changes as Ian wrote. There are Tocos 50k log pots offered online in good prices. They are subjectively well blending parts in this. Most Tocos on offer are linear pots so watch for that crucial detail in the various sellers descriptions.
Old 17th September 2018, 04:43 PM   #3388
Salas's Avatar
6V6 line preamp
It would lower the valve's now bias current roughly by four times rather. Whatever practical changes to the cathode resistor(s) values would not compensate a much raised THD result vs the original topology. Including the raised presence of higher harmonics than the second one. Some loss of level would take place too when for same I-bias.
Old 18th September 2018, 10:39 AM   #3389
the cathode follower version is quite stunning...
It is relay good preamp.
6V6 line preampHide this!Advertise here!
Help me design my DAC/Line Preamp. kuroguy Tubes / Valves 7 2nd April 2009 08:31 PM
preamp line ctt richwalters Tubes / Valves 1 7th March 2008 04:34 PM
Preamp for Line In and Mic blur Instruments and Amps 1 4th January 2007 04:02 PM
Line stage preamp, based on SY's "Heretical Unity gain line stage" Danko Tubes / Valves 23 18th July 2005 04:07 AM
Line preamp for 2A3 amp Petman Tubes / Valves 0 24th May 2002 03:11 PM
