Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Thread Tools
Old 27th November 2021, 01:52 PM   #11
Tubelab_com is offline Tubelab_com  United States
Tubelab_com's Avatar
Grounding the tab on the 5 volt regulator is OK in this case. Grounding the tab on the dual Schottky rectifier is NOT. Fortunately, it only needs a small heat sink.
Your washer was probably biting through the solder mask on the board near the mounting hole.
The mounting hole between the regulator and the 300B socket has a gold ring around it which is isolated. There is a space around that ring, and a large solid copper trace under solder mask nearby. The copper trace is the 5 volt supply feed to the output tube heaters. It runs on both sides of the board, and is huge since it would carry over 5 amps in a 2A3 build.
A mounting bolt, washer and nut must stay in the gold area, be insulated, or made of non conductive material to avoid shorting out the 5 volt supply. If the bolt and nut are small enough, leave the washer out or use a non conductive washer.
Tubelab, I blow stuff up so that you don't have to.
Old 28th November 2021, 12:58 AM   #12
Pooch is offline Pooch  United States
Yes, I left all the washers out on that side of the board and all is working. I'll replace with nylon washers on both sides, later. Thanks to all for the help.
Old 28th November 2021, 01:07 AM   #13
Something else I'd like to add. After I hooked up the cheap Habor Freight meters, for volts and bias. I couldn't get it to bias on one channel....would only come up to 8MA. So I switched the meter positions and all was well. If you use these cheap meters ( which I think are great for the price) watch out for meter failure or wire failure. It could put you on a goose chase.
  Reply to this post
No lighty up on 300bsHide this!Advertise here!
Thread Tools
FT: My JJ 300Bs for your Chinese 300Bs beeah Swap Meet 0 7th December 2014 01:59 AM
FS: x4 300Bs ARIYAHOOR Swap Meet 0 26th November 2012 07:03 AM
Anyone familiar with Hyuger HK-300BS kit from Hino Audio? truenorth Tubes / Valves 0 21st November 2007 07:51 AM
FS: Shuguang 300BS-C garbage Swap Meet 0 21st January 2005 12:00 AM
How does a VAC Renaissance 70/70 get 65W from 4 300Bs? Saurav Tubes / Valves 20 24th September 2003 12:51 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
