Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Thread Tools
Old 27th October 2020, 10:58 PM   #1
brl0301 is offline brl0301
Default tseii biasing question
Ive been running my tseii for a while now and all has been great. I decided today to check/adjust my bias since it had been a while. I am seeing some odd behavior while trying to set bias on the right channel. Im running just under 400 b+ and b- is showing around -200. I am trying to set current at 75ma. The left channel is nice and stable but the right channel continues to drift after i make an adjustment.
I checked the bias voltage at the 300b and it is around -66v and is stable even when the tube current is fluctuating. My first thought was the tube was the issue but I swapped tubes and the issue stayed on the same channel.
What should i be looking at to solve this issue? Thanks for any help
Old 28th October 2020, 02:19 PM   #2
w5jag is online now w5jag  United States
You might try touching up the solder joints on the resistor you are measuring across; maybe try a different set of test leads or meters to eliminate measurement issues before you suspect the amp.
Win W5JAG
Old 28th October 2020, 02:24 PM   #3
If it is not a measurement issue, then look for a leaky coupling cap on the side that is acting funky.
Win W5JAG
Old 28th October 2020, 11:26 PM   #4
Looks like it was simply a case of a dieing battery in one of my meters. After a fresh battery I was able to get consistant readings and was able to bias the tubes with no issue.
Its funny how something so stupid can create an "issue". Thanks for the suggestions
  Reply to this post
tseii biasing questionHide this!Advertise here!
Thread Tools
TSEII 300b to 45 swap brl0301 Tubelab 15 23rd October 2020 02:14 AM
TSEII with a Hybrid brigde? vernonb Tubelab 6 8th April 2020 03:15 AM
TSEII: all was going well until... Mr_Zenith Tubelab 14 22nd September 2019 02:57 PM
Biasing Question banffskiing Solid State 31 11th September 2011 06:38 PM
6v6 PP biasing question mor2bz Tubes / Valves 1 24th November 2010 07:46 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
