Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 15th June 2020, 06:11 AM   #1
minerwelder is offline minerwelder  United States
Default Another SSE Power Trans question
I've been reading every thread about SSE and have a question on Power trans here are two from Edcor.
1- XPWR222 Power transformer for a 120V, 60Hz. line to 750V (375-0-375) at 350mA center tapped, 6.3V at 6A and 5V at 6A. ? is 350mA to much.
2- XPWR033 Power transformer for a 120Vrms, 60Hz.or 240Vrms, 50/60Hz. line to 760V (380-0-380) at 200mA center tapped, 6.3V at 5A and 5V at 3A. I've seen others using this one but having problems with the 760V (380-0-380).
I'm looking at KT88, 90, 120 outputs, if the first one will work then the voltage will be better. I'm going with choke no SS and putting CFB and mode switches in, I'm using High efficiency speakers 35Hz to 20kHz, 92dB.
These are the OPTs I'm looking at GXSE15-5K - 15W, 100mA, Screen/Grid Tap 40%, Frequency Response 40~18K Hz., <1dBu.
Is the 560ohm 5W R17, R27 good or do I need 680ohm 5W, just getting build list made any changes or upgrades you see or know of would be listened to.
Thanks in advance Kevin
Old 16th June 2020, 10:44 AM   #2
Ok I'll add on and see if I can get help and learn, I was thinking of using the XPWR033 but was worried about the higher voltage since George recommends max of 375 per side, then I just found the XPWR222 now I want to make sure the 350 mA is not to much! I understand amperage and voltage for house and automotive but I'm new to tube amp high voltage.
Old 16th June 2020, 12:11 PM   #3
dwinstonwood is offline dwinstonwood  United States
My XPWR035 only get warm to the touch after hours of running.
740V (370-0-370) at 200mA center tapped, 6.3V (3.15-0-3.15) at 5A center tapped and 5V at 2A.
David
Old 16th June 2020, 02:03 PM   #4
Dale Saukerson is offline Dale Saukerson
Do not worry about excess amperage. Excess amperage is not forced thru the circuit or tubes. The tubes and circuit will only take what they need or are biased for. However the voltage output of a transformer will be somewhat higher if the circuit does not use the full capacity of the transformer. The voltage ratings for a transformer assume all windings are utilized and utilized to their published specs.
Old 17th June 2020, 03:12 AM   #5
Ok so the XPWR222 with 350mA on 375-0-375, and 6amp ,6.3v, and 5v could run a higher B+, so would the 5U4 tube for rectifier help bring the B+ down?
Old 17th June 2020, 06:12 PM   #6
The 5u4 does have a greater voltage drop than the 5ar4, which can be used to reduce B+ if that is an issue in your build.
Old 17th June 2020, 08:32 PM   #7
amandarae is offline amandarae  Philippines
amandarae's Avatar
Long time lurker here.
I have Hammond 374BX (375-0-375, 201 mA) in my amp using 5AR4 (GZ34) and have no problems at all. I built my unit in 2011 and thankfully performing as if it's brand new. I run SE using EL34 nowadays. I prefer it as it sounds close to my 300B (Tubelab SE of course!).
Also, 92 dB is not high efficiency if you are concern about the noise. It is not even mid-efficiency! The amp is dead silent using Altec 414A (running full range at 99dB) and Altec 802D (104 dB), so rest assured that if you build the amp per George and other users documentations here, you will be fine. Tubelab SE 300B in the middle, SE on the floor waiting its turn
Enjoy your build, you will love the amp!
Old 18th June 2020, 05:42 AM   #8
Thanks everyone I've been reading all the SSE builds and threads, I'm new to Tube amps, Just want to hear the sound that I did when I was a kid with my parents old console.
Nice System amandarae, I like your wood enclosures. I have the PCB from Tubelab and have my parts for the board in a project on mouser, that's why I'm asking questions to make sure on all the parts so I don't have to place second order!
Last edited by minerwelder; 18th June 2020 at 05:46 AM. Reason: wanted to add more info.
Old 20th June 2020, 04:56 PM   #9
Mmcaleer is offline Mmcaleer  United States
Love your setup. Tell me about those horn speakers. Those are wonderful.
Old 20th June 2020, 05:30 PM   #10
amandarae's Avatar
Thank you! As stated already, Altec drivers with Azura Horns with 1.4" throat (Azurahorn -Le Cleac'h Acoustic Horn Loudspeakers). Cabinet is Altec 614.
  Reply to this post
Another SSE Power Trans questionHide this!Advertise here!
Toroid Power Trans/Power Supply Question dtaylo3 Power Supplies 1 1st June 2016 07:21 AM
2300 ohm vs 5000 ohm output trans question speakerfritz Tubes / Valves 4 2nd October 2010 10:17 PM
Question regarding to output power trans hc167 Solid State 14 28th June 2008 09:41 AM
Power Trans question diaz028 Tubes / Valves 9 26th March 2008 07:58 PM
Power Trans Question cominup Parts 8 9th June 2005 08:06 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
