Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 5th June 2020, 03:47 PM   #1
minerwelder is offline minerwelder  United States
Default input
Ok this might show how noob I am for an old guy, multiple inputs into SSE is there a way or schematic to put multiple inputs into SSE (hagarman bugle 2, CD player and Dac?
Old 5th June 2020, 04:23 PM   #2
rayma is offline rayma  United States
Either located internally or externally, you'd need a three position stereo switch, and the RCA sockets.
Isolate the RCA grounds from the chassis, and connect them to the audio ground.
The drawing shows one channel, two are needed for stereo. You can omit the volume control if it is not needed.
You can buy boxes like this already made up, if that is preferable. An example:
RCA stereo input audio signal source Switch Switcher Splitter selector box 3 IN | eBay
inputHide this!Advertise here!
I2S adapter or HDMI/Ethernet input board recommendations (to replace USB input) Crom Digital Line Level 8 27th January 2019 10:05 PM
rj6 coaxial cable to wire the input connections to the input/driver tubes? dannoto Parts 7 24th October 2016 07:51 PM
analog input limiter and input clipping indicator for miniDSP 2x4 CharlieLaub miniDSP 8 10th May 2015 11:08 PM
Lower Screen Voltage KT88, choke input + Cap input supply BJosephs Tubes / Valves 16 15th October 2013 01:18 PM
current bias j-fet input 2sk170 ,2sj74 at input stage YUTK Solid State 11 2nd June 2005 03:34 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
