Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 8th May 2020, 11:30 PM   #91
spiggs is offline spiggs  United States
I thought that might be the case but feel better having some extra wire around rated for the job if the need arises.
Originally Posted by dwinstonwood View Post
The only thing I ended up using hookup wire for was AC signal wiring from the RCA inputs to the volume pot, from there to the board, and the AC ground wires from the negative speaker terminals, and the one RCA input ground.
The leads on my Edcore transformers and the choke were way longer than needed, and I cut most of them. I ended up using one of the lengths that I cut from a transformer for the IEC socket ground.
So, there really isn't any need to speak of for high voltage hookup wire with this design as long as your transformers still have long leads.
David
Six Year SSE Project Nearing CompletionHide this!Advertise here!
My build i nearing completion in its design. Tell me what you think FellCrustacean8 Multi-Way 3 14th September 2015 09:55 PM
IPL Speakers Nearing Completion - Wow! jonclancy Multi-Way 23 23rd June 2012 03:29 PM
Restore nearing completion bulgin Analogue Source 0 10th August 2009 10:40 PM
BOSOZ nearing completion/Aleph 5 just beginning. nate Pass Labs 5 15th August 2007 04:08 PM
Stereo Aelph 5 Tower nearing completion Coulomb Pass Labs 32 18th April 2005 03:07 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
