Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Thread Tools
Old 13th January 2021, 09:07 PM   #11
brl0301 is offline brl0301
Originally Posted by vernonb View Post
Thanks for the info brl0301
Coincidentally! my tubes are also Gold lions
Does your bias settle eventually?
Mine doesn’t seem to stop drifting till I crank the pot the other way
And with the other channel doing the same but in the other direction…its been confusing as to which tube is tube/channel is causing it,
What are your operating points for your 300b if you don’t mind me asking?
My operating point was ~405v at 68ma and a 3k opt….
Vernon
So Ive found that the iffy tube will run up pretty high over the normal operating point and after maybe an hour or so will eventually drift back down to the where it should be.
The reason the other channel moves opposite the one you are adjusting is because as one tube has more current flowing through it, it draws power away from the other tube. Same in the reverse, if you drop the current flowing through one, the current in the other will slightly increase. This is pretty normal and expected behavior from the tubes.
I would start by letting your tubes get nice and warm and then adjust both tubes to your 68ma target. If one of the tubes is having stability issues, it will drift significantly from where you set it while the other tube may move a much smaller amount in the opposite direction. Whichever tube is having big swings is the one with issues, or at least that has been my experience.
If both of your tubes are moving a ton without you adjusting bias then you may have some other issues going on.
I currently am running my tubes at around 400v b+ and 75ma. My bad tube will run up to around 100ma before it settles down. If i try to adjust the bias before it settles down, it continues to drift in whichever direction I had adjusted it last.
Old 14th January 2021, 08:21 AM   #12
vernonb is offline vernonb  New Zealand
Thanks brl0301
I think what is going on with my bias is slightly different,
It never settles, one tube will always “runaway”, kind of making the amp unusable (I think)
I’ve never been game to let it get much beyond 100ma when I’m watching
Maybe it would stop at some point but its still moving fairly smartly (say 30sec to get from 68ma to 100ma, I guess)
I will do some more tests over the weekend, I would like to be able just test one side of the amp at a time,
but I’m not sure running it with only one output tube is a good idea…
Maybe I just need to focus a bit harder on watching for changes between sides
Good to know your operating points are not too dissimilar to mine…Maybe they are just to hot for Golden lions?
Vernon
Old 14th January 2021, 04:01 PM   #13
Im pretty sure you can run woth just one output tube but id wait for someone more knowledgeable to confirm.
What you should try is adjusting the runaway tube halfway to where you want it ( say its at 100ma and you're shooting for 70ma, id adjust it to 85ma and let it drift down to 70ma) and see if thatll work. Thats how i eventually got my bias pots set close to where i needed them. After mine runs away on warmup, the bad tube will usually settle back down where i want it as long as i dont mess with the bias pot again
  Reply to this post
TSEII with a Hybrid brigde?Hide this!Advertise here!
Thread Tools
PSUD designer simulation for TSEII build lykkedk Tubelab 13 6th March 2020 05:18 PM
Odd 5AR4 rectiver (proberly blown) on TSEII Checkout lykkedk Tubelab 8 31st January 2020 08:32 PM
TSEII: all was going well until... Mr_Zenith Tubelab 14 22nd September 2019 02:57 PM
My wacky idea for a hybrid horn loaded woofer/planar widerange hybrid loudspeaker. Spasticteapot Multi-Way 0 30th November 2006 05:16 AM
help needed building a new brigde rectifier.... max29 Parts 1 26th November 2005 02:45 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
