Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 24th February 2020, 09:35 PM   #11
cogitech is offline cogitech  Canada
cogitech's Avatar
Simple SE Grid Voltage Question
Note: The title of the thread is actually wrong, because up until a few hours ago I thought grid voltage and "Vin" were the same thing.
I now understand they are not, and it is the "Vin" value that I was trying to understand - and I think I do now.
Thanks and sorry for the confusion.
Old 25th February 2020, 01:42 AM   #12
Tubelab_com is offline Tubelab_com  United States
Tubelab_com's Avatar
Technically speaking the output tube in an amplifier has both an AC voltage (the test sine wave, or the music signal) and a DC voltage applied to it. Both are required to control the flow of current through the tube.
These voltages are applied between the grid pin and the cathode pin of the tube. For most tubes the grid must have a negative voltage on it with respect to the cathode. The magnitude of this negative voltage will control how much current flows through the tube. A DC voltage of over -80 volts on the grid will cause all current to cease flowing through the tube. A voltage of near zero will cause maximum current flow through the tube. In an amp we adjust this idle voltage to get the desired idle current flow through the tube.
This DC voltage can be obtained two ways. The cathode can be connected to circuit ground, and a negative voltage can be applied to the grid of the tube, through a resistor, vacuum tube, mosfet, or transformer winding. The Tubelab TSE and TSE-II use this method.
The grid can be connected to ground through a resistor, or other path, and a positive voltage can be applied to the cathode, usually through a resistor in parallel with a bypass capacitor. The Tubelab SSE uses this method.
The DC grid voltage shown in your SE Amp Cad simulation shows a typical SSE type design with a 680 ohm cathode resistor. This puts 42.3 volts on the cathode and zero DC volts on the grid, resulting in an idle current of 63.2 mA and about 26 watts of tube dissipation at idle. Under IDEAL conditions with an IDEAL vacuum tube these conditions should not change from zero volume to the point of clipping.
Up to this point there is no signal applied to the amp, or the volume is turned all the way down.....and we are listening to nothing.
We can apply signal to this amp. This is an AC voltage that is fed to the grid along with the DC voltage. This is called Vin by SE Amp Cad.
If we applied a sine wave and just cracked the volume pot we might be putting 2 volts Peak to Peak into the grid of our tube. This will cause the grid of the tube to move up one volt to -41.3 volts on the positive peak of the sine wave, and move down one volt to -43.3 volts on the negative peak of the sine wave. This movement increases as we turn up the volume.
So Vin ("the AC drive level in peak AC volts") is the peak AC voltage coming from the 12AT7? How do I know what that value is? George used a value of 38 for Vin. Am I to assume that's the correct....."it (the 12AT7) can do a lot more than that with enough drive" do you mean drive on the amp inputs
The 12AT7 as it is set up in the SSE will have a gain of about 45 to 50. This is enough gain to ram 50 volts into the EL34 when driven from a typical consumer device without requiring a preamp. It also has enough head room to deliver over 100 volts to that poor output tube when overdriven. This is done to minimize distortion in the 12AT7, since it is not operated anywhere it's maximum capabilities. So, how much signal does our amp need.
This is where the 38 volts comes from.
Your sim shows that when 40 volts is applied to the EL34 under the conditions chosen, you will get 13.1 watts of power (neglecting OPT losses) and be creating 8.3% of second harmonic distortion, and 0.3% of third harmonic distortion. If you were to run the same sim at less Vin you would see less power output, and less distortion.
I typically run several dozen sims at various combinations of DC voltages, cathode resistors, and load impedances to find out what works best for a given tube. To get an apples to apples comparison, you keep ALL of the conditions the same from sim to sim except for what you are looking at. For example I could try a different cathode resistor, but keep all other things the same.
I always start at a low Vin and keep increasing it until I reach a distortion threshold that I do not want to exceed. The sims I did during the development of the SSE probably used a figure of 5% total 2H and 3H. My guess is that you will probably get pretty close to 5% if you back your 40 volts down to 38.
15 years have passed since I did those sims. SE amp cad was a good tool in the day, but it relies on good vacuum tube curves like any simulator, and like most sims, gives optimistic distortion and power output numbers. Today, I use LT Spice, and set my max THD threshold at 3%. LT spice allows for simulation of the entire amp at once, not just a single triode only stage. It is also far more involved to use.
Linear Technology actually came into the plant where I worked many years ago to demonstrate LT spice. Myself and their tech guy spent a couple hours simulating the SSE amp design. I probably still have that sim on a hard drive somewhere. I think it used a 6L6GC since that was the only model that we could find.
If you were to start at 1 volt and run 40 sims at one volt intervals and plot the results, you would see a typical distortion curve with pretty low numbers up to a point where it takes off and climbs near vertically. This is the point where more drive into the amp gives no more power output, only more distortion, often called clipping.
Once we find the Vin needed to push the output tube into clipping, we have the data needed to figure out how much gain is needed in the driver (12AT7) stage. That's where TubeCad was used 15 years ago. A typical iPOD or cell phone puts out about 0.75 to 1 V peak. A gain of 45 to 50 is needed to turn this into 38 volts of drive. A good CD player puts out more than this, so a volume pot is usually all that's needed between the CD player and the SSE.
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Old 25th February 2020, 03:46 AM   #13
cogitech's Avatar
George,
I know your time is spread thin so I really appreciate the time you have taken to explain this. It is nearly crystal clear to me at this point. The best part about building this amp is the fact that it is inspiring me to learn stuff that I have been curious about for quite some time. Now that you have explained the "big picture" I feel like there is some context for all the bits and pieces.
Working on projects like this keeps me sane, so again thank you for everything; designing the board, all the info and instructions on your site, and the after sales support and education. Amazing, really. I wish I could buy you a beer or two.
By the way, my amp will have the volume pot omitted and will be fed by a solid state pre-amp (for now). With my current 25w P-P EL34 amp, the pre-amp very rarely goes past half volume (it is passive at these volume levels). I don't anticipate any issues driving enough signal into the SSE.
Simple SE Grid Voltage QuestionHide this!Advertise here!
Grid-cathode voltage and grid current in 12AX7? rongon Tubes / Valves 59 21st July 2016 03:58 AM
Question about grid input signal voltage kb2wyl Tubes / Valves 19 4th November 2015 04:33 AM
simple question: is midpoint voltage setting for adjusting the DC Offset? Arnie75 Class D 7 29th April 2012 10:54 PM
JE simple 45 SE grid leak resistor question thafred Tubes / Valves 8 12th November 2010 07:24 AM
Control grid Voltage / grid stoppers... jon_010101 Tubes / Valves 2 4th May 2006 01:59 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
