Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 30th September 2019, 10:41 PM   #11
kevinaston1 is offline kevinaston1  United Kingdom
For my dummy load, I calculated the length of enamelled copper wire (heavy gauge) to give me 2, 4 and 8 ohms. I then wrapped it around a simple wooden former made of 38mm square timber, with tappings at the 2 and 4 ohm points.
The resultant "contraption" was mounted on the workshop wall above the bench.
Largest amp tested was an FPC10000; the dummy load was only slightly warm, but very clearly audible. As a bonus, if you want to monitor the signal waveform, just lean the probe on the wooden frame.
Kevin
Cheap 8 ohm dummy load for SSEHide this!Advertise here!
TDA7498 Dummy Load on unused output & 16ohm load question StevieF Class D 10 5th October 2018 07:07 PM
Building a cheap 250W dummy load Welcome Solid State 19 8th July 2016 07:33 PM
Adding a dummy load to prevent amp from being damaged by having no load? Joku Tubes / Valves 6 12th May 2015 08:27 AM
DDDumy Load, a versatile power dummy load tool dddac Equipment & Tools 6 14th January 2014 01:36 AM
Power load, dummy load (pic) luka Power Supplies 43 9th February 2012 03:50 PM
Copyright ©1999-2019 diyAudio
