Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 1st December 2019, 11:07 AM   #21
justmikey is offline justmikey  United States
Default OPT connections
It would appear on the secondary side that 6 is the common or - connection and then you select one of the others as the + depending on the desired impedance. It would appear on the primary side that P is the tube plate connection and B is the B+ connection.
Old 24th January 2020, 06:04 PM   #22
itsikhefez is offline itsikhefez  United States
300B SE OPT & Choke choice
Thanks justmikey, missed your post but thatís what I ended up doing.
The ISO are installed and working nicely.
I ran a square wave and FR measurement in ARTA.
Different circuits but comparing to this shootout,
http://www.tubesoundelectronics.de/t...ot_etf2009.pdf
Looks like the ISO are very good to excellent performers?
Can someone explain how to evaluate the HF resonance and overshoot as was done in the shootout?
File Type: jpeg 290F454B-CAA2-4EB3-9E89-D72B006424B7.jpeg (300.8 KB, 190 views)
File Type: jpeg E440354B-481B-4B1D-89CC-6A0A02901692.jpeg (293.5 KB, 190 views)
File Type: png C1D27478-6F1E-4F0C-ACE4-47DAAD77DBEB.png (58.4 KB, 188 views)
Old 17th June 2020, 11:36 AM   #23
cobar53 is offline cobar53  Australia
I have never seen a code for the power supplies wiring - such as what each of the T holes on the PCB equate to. Can someone help?
Wayne
Old 17th June 2020, 01:11 PM   #24
Tubelab_com is offline Tubelab_com  United States
Tubelab_com's Avatar
I was posting it in your two other threads as you wrote this. Once is usually enough.
Tubelab SE 300b Build Thread
Tubelab, I blow stuff up so that you don't have to.
Old 13th July 2020, 09:17 AM   #25
minerwelder is offline minerwelder  United States
So how much for transformers with shipping?
Old 13th July 2020, 04:43 PM   #26
When I bought them directly from ISO the cost was:
FC-20S output transformers -- $473/pr
LC-10-200DII choke -- $137/ea
$85 FedEx shipping to US from Japan.
I think they had a price increase since then, but at the same time there is now a US distributor so could influence prices and availability.
  Reply to this post
300B SE OPT & Choke choiceHide this!Advertise here!
Resistor choice for 300B amplifier repair AndyMcKay Tubes / Valves 7 28th April 2019 04:05 AM
300b power transformer and choke hottube Swap Meet 3 10th January 2018 10:25 PM
Grid choke considerations for 300b ClefChef Tubes / Valves 30 25th January 2017 10:58 PM
TSE power transformer & choke choice. mudchute Tubelab 22 18th May 2014 05:18 PM
TubeLab SSE choke / component choice? normaldotcom Tubelab 10 5th October 2013 02:49 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
