OPT connections
It would appear on the secondary side that 6 is the common or - connection and then you select one of the others as the + depending on the desired impedance. It would appear on the primary side that P is the tube plate connection and B is the B+ connection.
Thanks justmikey, missed your post but that’s what I ended up doing.
The ISO are installed and working nicely.
I ran a square wave and FR measurement in ARTA.
Different circuits but comparing to this shootout,
http://www.tubesoundelectronics.de/tabellen/messtabelle_ot_etf2009.pdf
Looks like the ISO are very good to excellent performers?
Can someone explain how to evaluate the HF resonance and overshoot as was done in the shootout?
I was posting it in your two other threads as you wrote this. Once is usually enough.
Tubelab SE 300b Build Thread
When I bought them directly from ISO the cost was:
FC-20S output transformers -- $473/pr
LC-10-200DII choke -- $137/ea
$85 FedEx shipping to US from Japan.
I think they had a price increase since then, but at the same time there is now a US distributor so could influence prices and availability.
