Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
Tubelab Discussion and support of Tubelab products, prototypes and experiments |
#21 | |
#22 |
If you have room for a big resistor, and there is some means for air to escape from the top of the chassis, then a big resistor with a stock Zener diode is fine.
I have found that having too many hot parts under the board in a small chassis with no vent holes will slow cook the board. This can cause harmless discoloration after several years, but heat constantly traveling up the resistor wires can cause solder joints to become brittle in a PCB based amp, or a point to point wired amp. A little air flow is your friend.
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before...... |
#23 |
Thanks for the quick response. I will be sure to provide plenty of air flow. I typically provide vent holes on the top of my chassis just above warm items such cathode bias resistors etc and use perforated sheet metal bottom plates.
#24 |
My plans are to have B+ in the 380V-395V range with 80mA bias.
The project is still under way but I ended up ordering the 200V zener for D6 and Mills MRA-10 10W resistors. The zener is on top but the big resistors are on the underside of the board (as you're planning) PT is Edcor XPWR178 also and will start with C4 = 47uF to try and reach that B+ range. My chassis will have an open bottom so hoping that provides sufficient ventilation. I may add 1-2 holes on top right above the resistors as you mention. |
Thread | Thread Starter | Forum | Replies | Last Post |
First time OB builder | Silent Screamer | Multi-Way | 395 | 3rd October 2018 10:49 AM |
First time ESL builder | jamesthomas128 | Planars & Exotics | 198 | 10th October 2016 02:31 PM |
first time builder | wendelltate | Full Range | 10 | 31st March 2014 08:59 AM |
Output Transformers... Decisions Decisions | RTF671 | Tubes / Valves | 10 | 27th February 2011 01:42 PM |
Decisions, Decisions - Help me select iron | kstylianos | Tubes / Valves | 7 | 14th February 2006 01:05 AM |
New To Site? | Need Help? |
