Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 14th July 2019, 04:42 AM   #1
ASRMX1 is offline ASRMX1  Mexico
Default Tubelab SE, one tube runs hotter than the other
Please Help,
I finished TSE with 300B. The filament voltage is 4.88 and 4.90. I get sound from both speakers, however the output tubes runs cool, and left channel have distortion. The tepmerature is about 50 celcius in left chanel and near to 80 celcius in right. The right channel sounds very well. I swap output tubes, transformer as well and input tubes and the left channel have distortion.
In advance for your help, thanks.
Old 16th July 2019, 10:07 PM   #2
w5jag is offline w5jag  United States
What is the plate current in the left tube?
If the left tube is not getting as hot as the right tube, the left tube may not be drawing current.
The problem in the left side could be that the bias is set incorrectly, or a bad MOSFET on that side.
Win W5JAG
Old 17th July 2019, 12:07 AM   #3
Thanks W5JAG. I'm a newby. Sorry if not explain myself.
I checked again all parameters, plate voltages and bias. I found the left channel channel bias was quite low. Then I adjusted again and bingo! Now is sounding quite fine. Sounds beautiful.
Tubelab SE, one tube runs hotter than the otherHide this!Advertise here!
HK990 right channel runs hotter jkasch Solid State 13 6th June 2019 01:34 AM
One tube brighter/hotter than the others Sabicas Tubes / Valves 35 15th October 2015 12:39 PM
why does 1 amp run hotter than another muscmp Instruments and Amps 11 9th October 2014 03:05 PM
Parasound HCA 3500 Left Channel Runs hotter than right Jeremyw112 Solid State 1 13th February 2013 10:15 PM
Using 46 tube in Tubelab SE? MZ Tubelab 1 21st January 2011 02:55 AM
Copyright ©1999-2019 diyAudio
