Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 15th July 2019, 10:31 PM   #11
zman01 is offline zman01  Bangladesh
Matts Tubelab SEE
Matt,
Here's an example of a ready made chassis which you can get from Mouser:
1444-17123 Hammond Manufacturing | Mouser
I think you have to order the bottom plate separately.
Btw, I have no experience with this chassis.
Did you install a log pot or a linear pot?
Old 16th July 2019, 05:57 AM   #12
flyingmattyboy is offline flyingmattyboy  United Kingdom
Hello. Thanks for the chassis suggestion.
My pot is actually a SMD stepped attenuator bought from ebay, mainly because I read some posts somewhere where people were saying they were good. The ebay description is below.
DACT Type SMD 21 Stepped Attenuator ( Audio Log Type / stereo ).
I am beggining to wonder about this to be honest, i am thinking about buying a cheap log pot and trying it out instead. If it is any good I could change it for an Alps or something better, but of the same values.
Matt
Old 16th July 2019, 10:58 AM   #13
Matts Tubelab SEE
Matt,
I've used the same type of attenuators in a few amps/preamps - they've worked fine...
Let's see what other folks have to say about "too much gain" in your case.
- Zia
Old 16th July 2019, 01:52 PM   #14
Cheers, is it possible I have installed it wrongly to get this effect? Sorry not very familiar with this stuff.
Matt
Old 16th July 2019, 05:25 PM   #15
I have done some experimenting tonight with different sources.
RESULTS ARE.
Homebuilt 834p based phono stage - super loud on click one, even louder on click two, click three would be way too loud for my ears in our room, so i didn't go there. silent in the home position.
Yamaha CD player - The same as above.
Smartphone playing amazon music through a Bluetooth Puck - the source volume is variable so i turned it right down to 1\3rd. This meant i was able to mess around with the Pot on the SSE more. Findings are - the volume is variable over the first 4 or five positions getting louder from position one to 5, position Zero is silent. There is no audible change that I can detect through the 15 or 16 positions after position 5 though. Sound Quality is superb no audible noise or distortion that I can detect anyway.
Any one got any ideas what might be causing this please, I am using Alpair 7.3 speaker drivers that are connected to the 8 Ohm tap. They are approx. 87db sensitivity but some do think that this is a conservative rating.
The hot spot on the valve does definitely move with the valve if you change them over from left to right. I also tried som 6P3S-E's that I have, these had an even glow throughout the hole tube so I am no longer worried about this.
Matt
Old 17th July 2019, 04:09 PM   #16
Sorry to Bump. But anyone got any ideas about my potentiometer problem?
Old 17th July 2019, 06:29 PM   #17
Matts Tubelab SEE
Matt,
Can you take a picture of how you have wired the pot?
Old 17th July 2019, 08:32 PM   #18
Firstly Zman thanks for sticking around. I am glad you are trying to help.
I sketched it out, sorry about the poor quality of the drawing.
Appreciated.
File Type: jpg PhotoPictureResizer_190717_210452045_crop_3105x2268.jpg (490.7 KB, 185 views)
Old 18th July 2019, 08:59 PM   #19
colnago55 is offline colnago55  United States
It looks to me from your diagram that you may have a wiring problem. Here's a diagram from the tubelab site. Only the center wire from each connector needs to go thru the pot.
The shields go to signal ground (as do a pair of pins on the pot.) Check that your pot is oriented correctly with the diagram and that you have no solder bridges (a problem I've had.)
Old 19th July 2019, 05:25 AM   #20
That was the diagram I used and I have triple checked against it and my wiring looked ok to me.
When you say " centre wire " is that the red and orange wires on the diagram?
Are the pots directional? Could I of soldered it in upside down compared to the Tubelab diagram?
Matt
Matts Tubelab SEEHide this!Advertise here!
Tubelab 45 SE martin155 Tubelab 7 23rd December 2018 04:03 PM
Tubelab se 45 need help. Rinfiniti88 Tubelab 14 30th November 2018 06:45 PM
Tubelab SE - 6A3? beeah Tubelab 6 25th January 2014 04:20 AM
Output Mosfets For Matts D200HC Amp Audioguy564 Car Audio 1 26th August 2009 04:11 PM
Copyright ©1999-2019 diyAudio
