Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 16th January 2019, 01:58 PM   #1
sv62 is offline sv62  Canada
Default Choosing and wiring selector for input jacks
Need help with tubelab sse build. I have two pairs of input jacks. Do I need a rotary switch or just a toggle switch (dpdt). Pls advise the type of rotary switch should I get if this is advisable. Pls advise the wiring as well for both options. Thanks.
Old 16th January 2019, 06:44 PM   #2
cbutterworth is offline cbutterworth  United States
Default Input selector
I used a high quality rotary switch from Elma. They’re not cheap, but are very good quality. The number of poles can be adjusted.
Mine was purchased here (I think). Michael Percy Audio Ordering Information
Charlie
Old 16th January 2019, 09:14 PM   #3
colnago55 is offline colnago55  United States
For two inputs I just used a dpdt switch such as
100DP3T1B1M1QEH E-Switch | Switches | DigiKey
Good luck
Old 16th January 2019, 10:28 PM   #4
Thanks for the reply. @colnago55, how do I wire using the toggle switch? Each pair of the jacks to the outer pins (side by side) and the middle pins go to the board?
Old 17th January 2019, 02:33 PM   #5
I'm using a volume control, so the middle pins of the switch go to the input of the volume control which connects to the board. If you are not using a volume control then the middle pins would connect to inputs labeled 1 and 5 on the board. The right channel and the left channel of an input are side by side on the outer set of pins of the switch.
Old 19th January 2019, 03:10 PM   #6
Thanks!
Old 19th January 2019, 11:21 PM   #7
moggi1964 is offline moggi1964  England
moggi1964's Avatar
Goldpoint Level Controls
Costly but very very good!
Pioneer XCHM86. Vista Phono1+ w/ TEAC TN-400. Loth-X Ion 1 & upgraded Genesis II+. WIP: Tubelab SE 300b
Choosing and wiring selector for input jacksHide this!Advertise here!
Input selector with DPDT relay: Is my wiring ok? Monrin Analog Line Level 23 9th July 2017 11:45 AM
Wiring a SEIDEN 32NEG Type as an input selector m4n Construction Tips 1 19th August 2013 05:54 PM
My TDA7294 Functioning!! Now choosing Selector... Hakimi Chip Amps 1 9th April 2011 12:42 PM
Relay input selector wiring help needed! zoranaudio Solid State 1 31st July 2008 07:58 PM
amplifier input jacks sss Solid State 5 1st January 2004 11:22 PM
Copyright ©1999-2019 diyAudio
