Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 5th October 2018, 03:59 AM   #1
somniumest is offline somniumest
Default SSE problem
I built a Tubelab SSE a 7 years ago and just recently i had a pair of kt88s start arcing. I replaced all the tubes and now audio is weak and muddy. I am going to pull out the multimeter this weekend but any suggestions on where to check. Just want to narrow it down.
Old 12th October 2018, 12:53 AM   #2
mike567 is offline mike567  United States
coupling and cathode capacitors
Old 12th October 2018, 01:27 AM   #3
Thanks Mike, C12 done blowed up. When i play through it I had mush in both channels. I am guessing I should recap? I will be honest I ran it 5. Years never turning it off.
Old 15th October 2018, 12:57 AM   #4
You may have lost the output tubes. I would check all passives and replace as necessary. The sse is not a complicated amp.
SSE problemHide this!Advertise here!
rel q50 sub amp problem! surfstu Solid State 13 14th November 2015 04:34 PM
Very Strange Problem with DIY Phono Stage (Possible Load Problem?) steve516 Analogue Source 9 26th February 2014 09:06 AM
Help needed please re Fatman 11 usb problem and ipod dock problem jml3p Digital Source 0 5th November 2013 12:19 PM
