#41 |
8K would be preferred; but 5K will also work fine. I doubt a difference can be heard between the two in either distortion or output.
If your OPT's have ultralinear taps, I would use them. I also use cathode feedback.
Win W5JAG |
#42 |
Looking to use a smaller PT with lower B+ and found this fairly recent experiment: http://www.r-type.org/pdfs/6v6-se-ul.pdf
I am interested in the 275V B+, 250V plate, ~390ohm Rk and 5K OPT load line. Given 275V B+, are there any further changes you're aware of beyond replacing R14 and R24 with a jumper? |
#43 |
About half way into this thread:
Tubelab SE: Removing MOSFETs? there is considerable information about using the SSE at lower than designed voltages. You should probably read it if you are going to go that route with an SSE. It should be helpful to you.
Win W5JAG |
#44 |
I read through that fairly long thread, very informative. Thanks for your work there.
I've started my own thread, hopefully you can chime in: Lower voltage SSE for 6V6 with custom PCB |
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
Stuffed Tubelab SSE Simple Single Ended Board + extras USA | boywonder | Swap Meet | 2 | 28th October 2013 06:50 PM |
Heat Resistant Plastic | lpd | Solid State | 18 | 11th March 2011 09:08 PM |
Auricaps in SSE and SSE as a guitar amp. | DanP | Tubelab | 5 | 12th July 2010 10:20 AM |
Child proof grills | Jimmy154 | Multi-Way | 14 | 16th December 2009 01:59 PM |
Child friendly speaker | d to the g | Multi-Way | 2 | 21st April 2007 03:15 AM |
New To Site? | Need Help? |
