Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Thread Tools
Old 4th May 2021, 10:54 AM   #11
Tubelab_com is offline Tubelab_com  United States
Tubelab_com's Avatar
There have been several threads about this in the Tubelab forum. The usual method for adjustable bias is to put the highest value 5 watt cathode resistor in the board, usually 820 or 750 ohm, then use a switch with a selection of resistors that get put in parallel with the 750 ohm resistor on the board to raise the current.
It is also possible to put a 750 ohm resistor in the board, then wire a pot and series resistor combo across that. Using a pot by itself allows for accidentally setting the resistance to zero or some other value that's low enough to force too much current through the tubes.
Since the switched resistors or pot are always used in parallel with the on board part, the current / power dissipation is shared between them. This allows for use of 3 watt parts if desired.
Simple, but not as easy to use method....
Put the 750 ohm resistor in the board. Make some resistors with alligator clips on the ends in the 2K to 3K range. Connect the clipped resistors in parallel with the 750 on the board as needed.
I used the 750 ohm by itself with an EL34 in triode mode. That gave me about 55 mA with the tubes I had. I clipped on some 2.2K resistors when I used 6550's in UL mode. This combo gave me 560 ohms for about 80 mA.
Tubelab, I blow stuff up so that you don't have to.
  Reply to this post
Variable cathode bias in SSE: 1k Ohm pot?Hide this!Advertise here!
Thread Tools
SSE bias question Pez Tubelab 10 16th December 2010 06:02 PM
Adjust cathode bias pot - both channels move together. Why? Hearinspace Tubes / Valves 17 30th July 2010 06:23 PM
Volume control : - pot' or pot' variable feedback resistor (gain) ? ash_dac Solid State 5 1st August 2006 05:07 AM
Riken Ohm 1k 68k Htguy Swap Meet 2 28th February 2006 01:33 AM
Supressed bias amplifier, automatic variable bias system. destroyer X Solid State 2 20th September 2004 10:24 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
