Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 5th September 2019, 11:48 PM   #491
DaMuffinMan is offline DaMuffinMan  United States
Very nice I love the attention to detail in yer build it shows.
Old 29th September 2019, 03:40 PM   #492
itsikhefez is offline itsikhefez  United States
Pictures of your Tubelab amp
Originally Posted by ASRMX1 View Post
My last posts were a failure. I could not post pictures. I hope this time works fine.
Based on the PT I am assuming this is a 300B?
Which Hashimoto's are those and how do you like them ?
Old 18th January 2020, 07:27 PM   #493
sunil is offline sunil  India
Originally Posted by Mr_Zenith View Post
Just completed my TSE-II this afternoon after about two months of painstaking work. This all started out as a populated PC board on a temporary plywood chassis; it has since morphed into the form seen below, which was inspired by an Atomic Age (aka "Googie") -themed coffeehouse I frequent while on travel.
The chassis measures 12" x 12" x 4" on the outside (not counting the feet), and is constructed of curly maple, cherry, and 1/8" 6061-T6 aluminum plate. I paid strict attention to matching the grain on the corners of the maple box, and finished all of the woodwork with several coats of nitrocellulose lacquer. All fasteners are 18-8 stainless to eliminate the possibility of corrosion.
To make it easier on others in my household I installed an Arduino-based infrared remote control that drives an ALPS motorized volume pot. The power switch light is used as a status indicator; normally steady when the power is on, it flashes whenever the IR sensor receives a signal. The Arduino unit receives its power through a dedicated 5V regulated supply.
To make it easier on myself, I took advantage of some unused space on chassis side to install a complete set of tip jacks for CCS and bias adjustment (thanks to moggi1964 and kilokat7 for the nudge in that direction!). The jacks are recessed for a cleaner look, and they're covered for safety. Finally, I laced all of the wiring into cables - just for the heck of it. Covering all of this is a custom bottom plate with plenty of ventilation.
Thanks to George for such an incredible design. Of all the amps I've built over the years, this has easily become my absolute favorite. In fact, one of the reasons it took me two months to complete was that I couldn't stop listening long enough to get any work done!
Nice job mate.
Old 10th February 2020, 01:33 PM   #494
lykkedk is offline lykkedk  Denmark
lykkedk's Avatar
Hi all here
Thought i've show some pictures of my ongoing buil.
I used some time to get the build "cooled" down
to my liking
I simply mounted som alu' bars & smalish sinks... The
fan is not really needed but good to have there for hot sommerday's
(when they come, if they do)...
Listening to it right now in livingroom...
I like the sound so far, marvelous 👍
More to come.
Rgds; Jesper
DCG3 Dual DCSTB, AK4490 Dual SuperDAC
AlephJ Mimi! http://www.diyaudio.com/forums/pass-...mimi-mini.html
Old 11th February 2020, 01:42 AM   #495
egellings is offline egellings  United States
Such blurry pictures. Fix that.
Old 11th February 2020, 02:29 AM   #496
cogitech is offline cogitech  Canada
cogitech's Avatar
Pics look good to me, lykkedk. Nice build so far.
Old 11th February 2020, 03:30 PM   #497
Impunity is offline Impunity  Canada
Impunity's Avatar
The pics are fine. It may be your download speed and youíre not staying on each image long enough.
Regards John L.
Old 14th February 2020, 12:32 PM   #498
lykkedk's Avatar
It's weekend
@Before_Taking_It_All_Apart_For_Finish_And_Paint_E tc...
Long term test for heat/thermal stability...
Rgds; Jesper.
Old 14th February 2020, 02:31 PM   #499
PDL is offline PDL  United States
Very nice. I really like the round corners of your chassis.
Old 14th February 2020, 06:19 PM   #500
Evenharmonics is offline Evenharmonics  United States
Sin Bin
Originally Posted by lykkedk View Post
It's weekend
Is your real name Mikkel Leicht? I wonder how you will move that thing to your listening area... A forklift maybe?
Pictures of your Tubelab ampHide this!Advertise here!
Tubelab SE amp question smbrown Tubelab 8 21st September 2009 06:05 PM
Tubelab SE 45... Super amp!? colivet Tubelab 0 26th August 2008 12:38 PM
Tubelab Simple SE & Edcor waam68 Tubelab 2 6th March 2008 01:15 PM
Switchable stages with Tubelabís hybrid MOSFET/ 845 SE amp? rick57 Tubelab 0 5th September 2006 08:56 AM
Especially for Tubelab: 845 amp 2.0 Giaime Tubelab 24 30th July 2006 04:39 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
