Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Thread Tools
Old 17th September 2020, 11:03 AM   #741
rock12 is offline rock12  United States
Is it ok to use carbon film resistors
Old 22nd September 2020, 09:09 AM   #742
itsikhefez is offline itsikhefez  United States
Tubelab Simple P-P
Carbon film is probably fine in most positions.. theoretically the circuit will be quieter with metal film.
George, hoping to get your thoughts on the compensation cap value.
I've tried 120pF, 270pF, 390pF and 470pF.
As you increase the value, the square wave gets nicer.
The issue though is that beyond 120pF, the amp distorts at about 3W of output.
I think this could be similar to an issue rkinze mentioned with new 12AT7's, although I've tried 3 different NOS types, a Siemens & Halski, Brimar and GE 6201 and all of them have the same issue.
I've also tried various output tubes JJ and NOS types, as well as both UL and Pentode connection, with the issue the same.
Technically, I can keep the amp with 120pF as I can drive the amp to clipping without observing this distortion, but the square wave is pretty ugly.
Old 13th October 2020, 08:07 AM   #743
Tubelab Simple P-P
I still have the instability issue as demonstrated above.
I have a different thread with more detailed information, the latest in this post: EL84 measurable distortion between different makes
If anyone has an idea of where to start looking, please let me know.
Thanks!!
Old 17th October 2020, 10:09 PM   #744
Tubelab Simple P-P
If I'm not using a pot, can I replace the 220K resistors across the input to something like 50K ?
Old 7th November 2020, 08:58 PM   #745
Tubelab Simple P-P
I'll give this thread another shot, as most of my questions above were left unanswered.
With UL and feedback the input sensitivity is about 0.5V for max output.
Is it OK to replace the 12AT7 with a 12AU7 ?
My DAC outputs 2V so I'm throwing away alot of signal and don't have much usable range on the pot.
Old 7th November 2020, 09:02 PM   #746
Duke58 is online now Duke58  United States
itsikhefez-- not being a smart aleck- why not go ahead and try it? What's the worst thing that can happen?
Old 7th November 2020, 09:13 PM   #747
Tubelab Simple P-P
Yea agreed, I am going to go ahead and do that. Still wanted to hear from someone with the expertise if there any issues of doing this.
I don't trust my ears enough to know if this is can cause some subtle problem with the amps operation.
Old 7th November 2020, 09:18 PM   #748
Tubelab says he blows things up so we don't have to. I doubt that you'll blow up any tubes switching out the 12AT7.
Old 7th November 2020, 09:59 PM   #749
Einric is offline Einric  United States
Einric's Avatar
Tubelab Simple P-P
I've rolled SO many different 12AU7 types into my SPP.
My favorite is the 6414.
The 12AT7 Baldwin Japan Blue Tip is really nice too.
Old 7th November 2020, 11:28 PM   #750
Tubelab_com is offline Tubelab_com  United States
Tubelab_com's Avatar
Yes, any resistor less than 220K is fine as long as your source can drive it. I have used 10K with a solid state source.
I have also tried lots of different tubes in the 12AT7 socket. Some work, some don't. Any tube that has the same pinout should do something, and not blow any parts. Something with largely different characteristics may need some resistor value changes.
I wouldn't use a 12AX7 since they don't like to run over 2 to 3 mA.
Tubelab, I blow stuff up so that you don't have to.
  Reply to this post
Tubelab Simple P-PHide this!Advertise here!
Thread Tools
Electrolyticless Tubelab Simple SE nic6paul Tubelab 26 20th August 2013 01:56 PM
Second Tubelab Simple SE board done budmaestro Tubelab 0 24th July 2008 01:18 AM
First Project Finished-Tubelab Simple SE waam68 Tubelab 2 12th April 2008 07:23 AM
Tubelab Simple SE & Edcor waam68 Tubelab 2 6th March 2008 01:15 PM
New SET: JE labs simple 45 or tubelab SE? cwujek Tubelab 14 27th November 2007 05:15 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
