Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Thread Tools
Old 1st October 2019, 11:58 AM   #721
audiojunky is offline audiojunky
Default spp help
I need help with my spp Im not a total novice Ive made at least 10 guitar amps ranging from marshalla to fenders to matchless all point to point made my own turret boards , this is my first stereo with a pcb thought it would be pretty straight forward but I cant seem to get it sorted I can just hear a signal if I put my ear to the speaker Ive Pulled the board checked all components my voltages seem okay its doing my head in.Ive traced a signal all the way thru to the primary out but when it comes back from the output tranny secondary its quieter than going in
Old 3rd October 2019, 02:29 PM   #722
Duke58 is offline Duke58  United States
Properly punctuated English translation: (This is what happens when I wake up at 4:00 AM, read the online newspaper and check DIY Audio afterwards. I read your post and thought it was because I'm groggy and haven't had my coffee. Promise though, starting tonight, I'll try and stay up later so I don't wake up so early. Thought to myself, self, with this translation, maybe someone on the forum can help this person out.)
I need help with my SPP. I'm not a total novice, I've made at least 10 guitar amps ranging from Marshall to Fender's to Matchless- all point to point. I also made my own turret boards. This is my first stereo with a PCB. Thought it would be pretty straight forward, but I can't seem to get it sorted.
I can just hear a signal if I put my ear to the speaker. I've pulled the board, checked all components. My voltages seem okay. It's doing my head in. I've traced a signal all the way thru to the primary out, but when it comes back from the output tranny secondary, it's quieter than going in.
(I'm also not sure what a output tranny secondary is? Do you mean the signal from the anode to the input of the output transformer is higher than on the output of the transformer, where the speakers are connected? This mixes me up more than a feather in a whirlwind).
Old 3rd October 2019, 02:35 PM   #723
Tubelab_com is offline Tubelab_com  United States
Tubelab_com's Avatar
I recently returned from a 2700 mile road trip which involved periods of poor, or no internet availability. I received the same question by email, and a day later another email stating that it had been fixed, and was a grounding problem. My guess is a short across the OPT secondary.
Tubelab, I blow stuff up so that you don't have to.
Old 3rd October 2019, 02:43 PM   #724
Mr. Tubelab,
Thank you for clarifying that.
If there's one thing in this world that I hate more, it's when a series of long posts are never concluded, a solution isn't provided. It's like never having closure when a relationship goes bad, or watching a foreign movie with a sad ending.
Old 4th October 2019, 12:28 AM   #725
Sorry guys yeah i let george know but forgot about diy. Yeah it was a short from the output transformer, its always something really simple.and sorry about my aussie slang and bad gramma , my wifes always having a go at me about that
Old 10th October 2019, 01:57 PM   #726
Francois G is offline Francois G  United States
Originally Posted by audiojunky View Post
.....sorry about my aussie slang and bad gramma .....
Oh dear, sorry to hear about your bad Gramma .... mine is the sweetest little-old-lady you ever met😄
Old 4th November 2019, 09:35 PM   #727
Skorpio is offline Skorpio  Denmark
A diode or a lamp is often placed between the grid and the cathode of the phaseinverter, to prevent arcing at start-up.
Is this not needed here?
Old 4th November 2019, 10:17 PM   #728
In some circuits there is a potential for large current flow, and some protection is a good idea.
Here there could be a possibility for 4 mA or so (B+/100K resistance) to flow from grid to cathode in the 12AT7 if the rectifier conducts before the 12AT7 does.
Worse case is a 6CW5 amp with a solid state rectifier, since B+ is instant. The cathode of a 12AT7 can support well over 10 mA in normal operation, so it's not harmed at 4 mA. A positive grid will conduct, keeping the grid voltage low, 10 volts or so. This keeps the grid dissipation well below 100 milliwatts during the short time that this is happening.
Old 1st September 2020, 05:21 PM   #729
itsikhefez is offline itsikhefez  United States
Tubelab Simple P-P
Is it possible to modify this circuit to use 12AX7 instead of 12AT7 ? I have many 12AX7's that I could use but no 12AT7's.
Also, how much $$ should I send in order to order this board?
Old 1st September 2020, 07:51 PM   #730
I have never tried to use the 12AX7 as the phase inverter in a HiFi amp, although it is often seen in guitar amps, but distortion is not always a problem in guitar amps.
The 12AT7 in the SPP runs at 5 to 10 mA of current in the SPP depending on the B+ voltage. A 12AX7 is typically run at 1 to 2 mA, and not specified above 3.5 mA. It would be possible to change the resistors in the circuit to lower the operating current, but this would increase the THD at high signal levels. The grid of many EK84's, especially some of the new production tubes can draw current even when it is still slightly negative. This is why I kept the current through the phase inverter as high as practical to avoid imbalance as one grid tries to draw some current.
The SPP board is $35 and Shipping is $8 to US addresses.
Tubelab Simple P-PHide this!Advertise here!
Thread Tools
Electrolyticless Tubelab Simple SE nic6paul Tubelab 26 20th August 2013 01:56 PM
Second Tubelab Simple SE board done budmaestro Tubelab 0 24th July 2008 01:18 AM
First Project Finished-Tubelab Simple SE waam68 Tubelab 2 12th April 2008 07:23 AM
Tubelab Simple SE & Edcor waam68 Tubelab 2 6th March 2008 01:15 PM
New SET: JE labs simple 45 or tubelab SE? cwujek Tubelab 14 27th November 2007 05:15 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
