The Lounge A place to talk about almost anything but politics and religion.
Are Discrete components better than Opamps ?
Old 24th October 2006, 12:35 AM   #1
jsa_ind is offline jsa_ind  United States
Default Are Discrete components better than Opamps ?
Hello Everyone,
Is it true that discrete components would sound better then IC's ?
I mean there is so much of advancement in IC's I thought they would at least would be as good as discretes...am I mistaken to have such a perception ?
Certainly http://www.bursonaudio.com/Why_Burson_HDAM.htm thinks otherwise !
Thanks,
Junia.
Old 24th October 2006, 02:09 AM   #2
Geek is offline Geek
Geek's Avatar
Kind of depends on application. Both have their places, IMO
Old 24th October 2006, 02:15 AM   #3
paulb is offline paulb  Canada
Default Re: Are Discrete components better than Opamps ?
No.
Old 24th October 2006, 03:16 AM   #4
I_Forgot is offline I_Forgot  United States
I_Forgot's Avatar
There are certain type of components that have no IC equivalent. Transformers, for example. It is hard to duplicate or exceed transformer performance with op-amps, and of course, op-amps require power and other components to function.
IC's are good at making circuits that are flexible, and consistent. The matching of transistors in an IC can be very nearly perfect which can lead to better performance than discrete parts which can't be matched as well. The manufacturing techniques used in IC yield parts that behave pretty consistently from one device to the next.
OTOH, you can make a class A power amp with an IC output stage.
Both discrete and ICs have their uses.
I_F
Old 25th October 2006, 09:22 PM   #5
R.I.P.
have a look at Walt Jung's site and you will find that the opamp man even has a discrete buffer in his notes.
Even he recognises that discrete has advantages.
But a plain simple yes would be stretching it a bit.
regards Andrew T.
Old 26th October 2006, 03:03 PM   #6
I_Forgot's Avatar
I_F
That was supposed to say "CAN'T".
I_F
Old 26th October 2006, 03:09 PM   #7
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
But you CAN !
Old 26th October 2006, 04:20 PM   #8
aerius is offline aerius  Canada
Depends on what you want to do. For something like a small portable headphone amp for an iPod, opamps are the way to go. For a 800W class A monoblock amp, you pretty much have to use discrete parts for everything except the input stage.
Old 26th October 2006, 04:38 PM   #9
R.I.P.
even for line drivers, ICs are at their limits. Anything more than a few mA and they are into ClassAB.
600ohm and 75ohm driven to 20dbu is hard going and to 24dbu is nearly impossible for a single IC.
That's why composite topology is being used but then the cost doubles.
Discretes can overcome these current/temperature effects with careful design.
regards Andrew T.
Old 26th October 2006, 05:09 PM   #10
phase_accurate is offline phase_accurate
If there is not much output current demand like higher- order active filters then you must be very good in analog design to beat good op-amps.
Someone once claimed on this forum that he wasn't able to her the difference between a straight wire and a chain of op-amps used as voltage followers (which is even the worst usage of an op-amp anyway).
Charles
Are Discrete components better than Opamps ?Hide this!Advertise here!
FS: Power Chip OpAmps and other OpAmps & D to A Converter dtm1962 Swap Meet 4 12th January 2006 10:07 PM
best I/V stage for ad1955 with discrete components Jaap Digital Source 2 26th January 2005 06:17 AM
discrete vs. IC opamps? has anyone tried the pass labs design? dorkus Pass Labs 22 28th June 2001 01:02 AM
Copyright ©1999-2019 diyAudio
