The Lounge A place to talk about almost anything but politics and religion.
The Black Hole......
Old Today, 01:32 PM   #2571
elektroj is offline elektroj  Europe
Originally Posted by Max Planck View Post
On the subject of vinyl does anybody know of a free VST plugin to implement vinyl cutting lathe mastering...ie mono below 200Hz, rolled off tops etc please ?.
Free? For lathe mastering? You have a lathe but want a free ride?
Ok, try this one:
GVST - GMonoBass
or this one, 32 bit only
Basslane | Tone Projects | Unique Audio Plugins
Old Today, 01:42 PM   #2572
billshurv is online now billshurv  United Kingdom
billshurv's Avatar
I don't think there is anything mysterious going on once the electronics are sorted then cables are the final GU polish works for me.
Clearly a thing with antipodeans with 'Max' in their user name. I'll stick with engineering a solution thanks.
Old Today, 02:58 PM   #2573
simon7000 is offline simon7000  United States
These are two tests of IM distortion. Note the "Test" is called IM 19 & 20 but that is not where the actual IM is located. It is just above 2Khz. Note the short silver jumper wire is better than the two premade cables tested. You might also note the effectiveness of shielding.
Also shown is the results of soldering 100 jumpers on a small PC card with different solders. My conclusion is that good solder joints are almost exactly the same no matter what the formulation and cables actually can have differences. Keep in mind a cable consists of wires and connectors.
Old Today, 03:15 PM   #2574
Evenharmonics is offline Evenharmonics  United States
Max Planck = Max Headroom?
Old Today, 03:22 PM   #2575
scott wurcer is offline scott wurcer  United States
scott wurcer's Avatar
Need the goop mentioned first.
"The way up and the way down are one in the same"
Old Today, 04:01 PM   #2576
chris719 is offline chris719  United States
Yeah, there's no way he could resist.
Old Today, 04:27 PM   #2578
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
I did wonder when he first appeared, but I don't think Dan has enough self control to hide his true self
Old Today, 06:02 PM   #2579
Unconvinced at this moment.
The Black Hole......Hide this!Advertise here!
First ever black hole image Bigun The Lounge 126 26th April 2019 04:59 AM
Electronic hobbiest's black hole Frazzled Equipment & Tools 39 26th April 2007 03:11 PM
Black hole? Nappylady Multi-Way 24 12th June 2004 11:26 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
