The Lounge A place to talk about almost anything but politics and religion.
When tying a knot solves most of the hum issue!
When tying a knot solves most of the hum issue! Please consider donating to help us continue to serve you.
Old 13th October 2019, 11:11 PM   #1
kodabmx is online now kodabmx  Canada
Spreading triode love.
Default When tying a knot solves most of the hum issue!
Yup... 120Hz hum even though the amplifier is powered by switching supplies... A simple knot fixed most of it...
Never be afraid to try the cheap solution first LMAO.
Old 13th October 2019, 11:17 PM   #2
Galu is offline Galu  Scotland
Can't say I'm knot impressed!
Old 13th October 2019, 11:25 PM   #3
tomchr is offline tomchr  Canada
tomchr's Avatar
That's hilarious. It'd be interesting to play a bit more to understand what changes. Are you putting more strain/stress on the connectors, thereby causing them to connect better or something?
Tom
Modulus-86, 186, 286, & 686: 40-240W (8Ω), <-120dB THD. HP-2 Headphone Amp: 660mW, <-130dB THD. Taming the LM3886.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Old 13th October 2019, 11:43 PM   #4
chrisb is offline chrisb
Have you submitted your patent application yet? If not the boys at Monster will scoop it out from underneath you.
All kidding aside, if it works, it works.
Technology honors no Hippocratic oath
Old 13th October 2019, 11:58 PM   #5
vinylkid58 is offline vinylkid58  Canada
vinylkid58's Avatar
I did that to a speaker wire once, and an EE friend saw it and said I had created a filter.
Old 14th October 2019, 12:52 AM   #6
C'mon - where have you hidden the op-amps?
Old 14th October 2019, 01:05 AM   #7
Fast Eddie D is offline Fast Eddie D  United States
I took apart a flat screen TV (scavenger hunt) and saw that the mains power lead was looped once through a ferrite cylinder. I did some internet sleuthing and found out that this was a ground loop breaker scheme for eliminating hum. I took it out and used in my preamplifier.
Does it work? Well there's no hum or ground loops. I've made it a point to grab these out of any flat screen I see in the electronic recycle dumpster. I also saw where Mouser and Digi-Key sell these.
Old 14th October 2019, 01:39 AM   #8
wiseoldtech is offline wiseoldtech  United States
wiseoldtech's Avatar
Indeed, ferrite chokes are good for eliminating certain interferences.
I've got a couple of them clipped around various devices around the house.
Bohemian Guru Professional
Old 14th October 2019, 11:43 AM   #9
DF96 is offline DF96  England
If the knot is actually solving the problem, then the problem is due to quite high frequency RF. However, more likely that the knot is a coincidence.
Old 14th October 2019, 01:09 PM   #10
jneutron is offline jneutron  United States
jneutron's Avatar
Is that cable from a turntable?
Is that green alligator clip jumper your phono ground?
If both are yes, it is proximity between then that reduces ground loop hum.
I wrap my to ground tightly around the tt cables up to the binding post.
Jn
I hate all these smart gadgets..I refuse to buy things that are smarter than me. I've made a list of those things... Cabbage just made the list.
When tying a knot solves most of the hum issue!Hide this!Advertise here!
Tying conductors together for signal wiring in chassis force of 1/2 Construction Tips 10 22nd December 2017 10:49 AM
Tying aux in directly to the stock amp (TDA7560) tdarms Car Audio 1 8th July 2013 05:51 PM
Tying it all together - Low Noise Internal System Grounding Zero Cool Power Supplies 4 23rd August 2011 07:46 AM
Hum issue e_fortier Class D 6 3rd March 2009 03:42 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
