The Lounge A place to talk about almost anything but politics and religion.
When tying a knot solves most of the hum issue!
Old 16th October 2019, 12:22 PM   #31
Galu is offline Galu  Scotland
Originally Posted by mondogenerator View Post
Ropey* Adjective also used to describe bacterial infected fermentation.
Are you saying my sense of humour is infectious?
Old 16th October 2019, 12:27 PM   #32
mondogenerator is offline mondogenerator  England
mondogenerator's Avatar
Well... something is catching
Difference of opinion is awesome.
It's what makes the world we live in a verdant tapestry of beauty.
Old 16th October 2019, 10:14 PM   #33
kodabmx is offline kodabmx  Canada
Spreading triode love.
Originally Posted by DF96 View Post
Maybe a slight difference in valve capacitance meant that the other valves tuned to a different station? Parasitic oscillation? Alternatively, maybe you were hearing some residual AM on the carrier.
Any number of things really, but my construction technique has vastly improved from those days. I didn't even use shielded wire from the RCA to the grid... (Neither did my commercial "Belcor" receiver though).
Speaking of shielded wire... You only connect the shield/ground at one end, yes? I connect it only at the RCA end of the link.
Old 16th October 2019, 10:20 PM   #34
cal3713 is offline cal3713
If the knot is actually solving the problem, then the problem is due to quite high frequency RF. However, more likely that the knot is a coincidence.
I'm sorry, but I believe "more likely than knot a coincidence" is proper usage here.
Old 18th October 2019, 06:43 PM   #35
nezbleu is offline nezbleu  Canada
nezbleu's Avatar
You need a signal and a return to complete a circuit. One way to do that is to connect the RCA outer conductor to chassis, and connect signal ground of PC board to chassis at some point, and that completes the circuit. It also makes a big loop and the shield (connected at only one end) does next to nothing because return current does not pass through the shield. Alternatively, isolate* the RCA from the chassis and run a shielded cable with shield connected at both ends, which completes the circuit, reduces loop area, and makes the shield much more effective.
*but with a small cap from RCA outer connector to chassis to make a shorter path to ground for very high frequency noise.
"In the world of commerce and finance it is thought quite remarkable if a man is both clever and honest." -- Demosthenes
Old 19th October 2019, 07:10 PM   #36
KaffiMann is offline KaffiMann  Norway
Fanatic
KaffiMann's Avatar
Indeed!
Whoever said that the occasional bend in the inductor was knot important?
https://pdfs.semanticscholar.org/004...69d66feb3c.pdf
Things are starting to happen, work in progress: https://kaffimann.com
Old 19th October 2019, 07:15 PM   #37
mchambin is offline mchambin  France
The knot makes a spintronics effect like in Bybee products.
Transistor junction temperature is not transistor case temperature.
Old 20th October 2019, 07:34 PM   #38
Fanatic
KaffiMann's Avatar
Quite so! It does certainly put a new spin on tying the knot.
Old 24th October 2019, 09:56 PM   #39
Knot V2.0... Even better hum rejection...
Now I just need to chase the hiss (brown noise actually). I have a LOT of gain so if I crank the volume without signal I hear noise...
Old 25th October 2019, 07:29 PM   #40
Vovk Z is offline Vovk Z  Ukraine
Originally Posted by lcsaszar View Post
Don't stop here. Some of these must improve the sound:
Knot table - Encyclopedia of Mathematics
But be careful - some of them definitely can summon the devil!
When tying a knot solves most of the hum issue!Hide this!Advertise here!
Tying conductors together for signal wiring in chassis force of 1/2 Construction Tips 10 22nd December 2017 10:49 AM
Tying aux in directly to the stock amp (TDA7560) tdarms Car Audio 1 8th July 2013 05:51 PM
Tying it all together - Low Noise Internal System Grounding Zero Cool Power Supplies 4 23rd August 2011 07:46 AM
Hum issue e_fortier Class D 6 3rd March 2009 03:42 AM
Copyright ©1999-2019 diyAudio
