The Lounge A place to talk about almost anything but politics and religion.
What causes grainy sound
Old 16th October 2019, 08:38 AM   #601
indra1 is online now indra1  Indonesia
Originally Posted by johnego View Post
... I assumed they are very low bandwidth.
Vladimir was talking about the 1T910A Ge PNP 35W 30MHz ft.
Old 16th October 2019, 08:46 AM   #602
picowallspeaker is offline picowallspeaker  Italy
picowallspeaker's Avatar
I had a very good sound from two simple projects that Rockmandrake published along here 10 years ago. AD 147 or similar...
Being very old transistors, they deteriorate very quickly for the reason of the white powder inside them that changes over time.
It's like learning sex during the Victorian era: you get to the wedding night and there are many things to do that you never imagined.
Old 16th October 2019, 11:05 AM   #603
mountainman bob is offline mountainman bob  United States
mountainman bob's Avatar
My_Ref Fremen Edition - Build thread and tutorial. The schema is in the google drive link of the first post. May be you can find the PCB somewhere on ebay or something.
Thanks John,
And thanks to everyone for the help in trying to figure things out.....whether or not the differences I hear are only my imagination they are there none the less.......maybe everyone should enjoy a bit more imagination?
Old 16th October 2019, 11:27 AM   #604
Bob also mentioned slew rate, but I think JC likes high slew rate in his amps, so it is not because of the lack of it. High slew rate tends to increase the overshoot factor. But from Stereophile measurement I could see that the Parasound has so smooth squarewave. May be JC tried to make this smooth (for marketing purpose) and the effect is something that Bob didn't like. From Bob description of the sound, I thought there is possibility that base resistors have been aggressively used. But if we follow the logic that all amps sound the same, it could be just Bob's ears
Here’s a pic if that’s the same one.....
https://www.stereophile.com/images/1115PHalofig14.jpg
This is description from Alterman audio.....
“FETs. His design uses balanced push pull complementary circuits. Dual JFETs are used for the input section. FETs are Field Effect Transistors which combines many of the sound characteristics of tubes with the advantages of transistors. Matched MOSFETs are used in the driver stage.
The output stage uses 12 high voltage, high current bipolar transistors”
Here is a link to the stereophile measurements......
Parasound Halo Integrated integrated amplifier Measurements | Stereophile.com
Anyone see anything that would equate with what i’m hearing?
Thanks,
Bob
Old 16th October 2019, 03:46 PM   #605
VladimirK is offline VladimirK  Uzbekistan
Output resistance 0, 075 R with 1t910a, and 0, 018 R with 1t813a
Old 16th October 2019, 06:08 PM   #606
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
Looking at the datasheets only the 910 has a a spectacular Ft. The 813 sheet mentions only the switch off delay which is probably irrelevant for linear applications.
The 813 appears a lot easier to source but is it worth it? Big sonic difference to the 910?
Old 17th October 2019, 02:09 AM   #607
Sound is a bit more detailed with 910, but their reliability is not so good for se operation. Also transistors forming output triplet are germanium. Ge has less base region resistance in chip, theirfore less output resistance
Old 17th October 2019, 02:49 AM   #608
Ft for 813 should be around 10MHz, by analogy with gt806 transistor. 813 has two 806 chips in parallel.
Old 17th October 2019, 05:29 AM   #609
johnego is online now johnego  Indonesia
1T910A. Does T stand for T-rex? Vladimir knows good stuff, I think the Ge I have access to won't be half close. BTW, I need to make a commitment now not to waste my time thinking about Ge anymore...
What causes grainy soundHide this!Advertise here!
One channel grainy sound tubob Tubes / Valves 6 17th October 2012 07:05 AM
The Ultimate Sound Improving for Compact Disc's through Patent-Pend.CD Sound Improver tiefbassuebertr Digital Source 145 25th April 2011 07:39 PM
Eighteen Sound (18 Sound) NSD 1095N Compression Drivers and XT1086 Horns opc Swap Meet 6 1st May 2009 03:48 AM
grainy preamp gain sourgrout Tubes / Valves 12 10th March 2005 04:49 AM
Grainy speaker finish DIY_Peter Multi-Way 3 20th October 2003 07:11 AM
Copyright ©1999-2019 diyAudio
