Silver oxide is a good conductor while almost all other metal oxides are either isolators or semiconductors.I'd be interested to learn the conductivity of copper oxide (that's what I'd call oxidated copper - I don't know how else to name it, in light of recent post: copper sulphate perhaps?).
Kind regards,
HK
While silver is reacting with sulphur (from SO2 in the air), copper is forming oxides. There are two oxide variants. One of them is a good semiconductor and was used in he early times of electronics as a material to build rectifiers long before germanium and silicon were used.
That's the reason for nickel, rhodium, gold and platinum top layers on contact surfaces especially for harsh environmental conditions.
The reason for using silver especially for RF is its conductivity which is much better than e.g. gold. Despite the fact that it is not as noble as the above mentioned metals it is the only metal not leading to contact loss when oxidizing
I researched the web and found that silver does not oxidize, but tarnishes with sulphide. I read somewhere that electrical conductivity of silver sulphide at room temperature is about 1000 times that of copper.
I am sure that thin layer gets abrased when the contact surfaces are sliding on each other.
I treat my connectors with contact lubricant, and never had any problem.
- Member Areas
- The Lounge
- Why not Silver?
