The Lounge A place to talk about almost anything but politics and religion.
"Life Hacks"?
"Life Hacks"?
Old 13th July 2019, 01:23 AM   #11
tsmith1315 is offline tsmith1315  United States
tsmith1315's Avatar
Pencil lead filings mixed with Elmer's white glue and water to repair a worn contact on a membrane switch. Good emergency repair, but only lasted a couple weeks in constant use.
Tim
Old 13th July 2019, 06:08 PM   #12
Ultima Thule is offline Ultima Thule  Europe
Ultima Thule's Avatar
Temporary tap water lever waiting for replacement part.
Old 13th July 2019, 06:22 PM   #13
kodabmx is offline kodabmx  Canada
Affordable triode connected sweep tube amps.
"Life Hacks"?
Nice. reminds me of the time my Dad used a pair of vice grips as the VHF channel knob for an old TV. Why buy a new knob, right? LOL I still remember changing the channel with it and I was only about 3 years old.
Old 13th July 2019, 06:46 PM   #14
Trollet is offline Trollet  Sweden
Trollet's Avatar
"Life Hacks"?
As we sometimes say in Sweden - farmers mend everything with binding wire and ductape
A diy'er finds solutions and saves money.
Others pay for solutions.
Figge.
Old 15th July 2019, 02:19 AM   #15
Tubelab_com is offline Tubelab_com  United States
Tubelab_com's Avatar
I had an old Honda 305 CC motorcycle. It was given to me for free because the splines were worn smooth on the shaft to which the gear selector lever was attached. I rode it for nearly a year with two pair of Vise Grips as the shifter.
In an attempt to mock up a big vacuum tube test amp using stuff that I already had, I started with my working 845 SE amp, removed the tubes and wired in an 833A tube with cheap Radio Shack clip leads. The filament of an 833A needs 10 volts and 10 amps, so a suitable transformer was found, and it was connected to the 833A tube with a pair of vice grips which also served to hold the tube upright. The plate and grid connections to the big tube were made with hose clamps.
The 1KV power supply in the 845 SE wasn't enough, so I wired in a 1500 volt 1/5 amp power supply from a Motorola VHF base station transmitter. I again used Radio Shack clip leads.
This existed for about 10 days of testing and disturbing the peace. It made about 200 watts which made quite a racked feeding a pair of 10 inch EV speakers with 100 db sensitivity, each.
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Old 16th July 2019, 03:08 AM   #16
wg_ski is online now wg_ski  United States
Originally Posted by kodabmx View Post
Why buy a new knob, right?.
The AC temp control in my oldest pickup truck still has to be operated with needle nose pliers. The shaft is too worn down for a knob to stay on it anymore. The pliers live in the console.
Old 16th July 2019, 04:25 AM   #17
HeyBill is offline HeyBill  United States
During my college days I made a water heater using an aluminum keg with a conduction tube and heater element inserted using a modified wooden bung. l taped a thermostat to the keg. Worked great for short showers.
What's that smell?
Old 16th July 2019, 11:09 AM   #18
"Life Hacks"?
I had a light dimmer like this. I hot glued it on... Maybe that would work?
I have a pot with a 1/8" shaft. I'm using part of a drywall anchor to make it 1/4" so I can use a standard knob.
Old 16th July 2019, 11:12 AM   #19
"Life Hacks"?
Awesome! How did you insulate it electrically?
Old 16th July 2019, 12:15 PM   #20
The wooden bung isolated the keg, but it wasn't a three wire plug. The keg was on a wooden stand. Not very safe.
What's that smell?
"Life Hacks"?Hide this!Advertise here!
Rockford "25 to life" Power 1000 ps transistors Deadly Sones Car Audio 4 19th June 2019 02:17 PM
Avoiding tv/advertising "Don't live life without it" - American Express brainwashing? VenusFly The Lounge 1 3rd September 2018 03:27 PM
"Real Life" Bass recordings gmikol Subwoofers 21 15th August 2006 03:39 PM
"life after the oil crash" yeah right MetalDemonics30 The Lounge 15 7th May 2004 04:32 PM
Copyright ©1999-2019 diyAudio
