The Lounge A place to talk about almost anything but politics and religion.
Water filled tubes
Water filled tubes
Old 21st January 2019, 05:40 PM   #1
Osvaldo de Banfield is offline Osvaldo de Banfield  Argentina
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
Default Water filled tubes
I got some compactron tubes whose vacuum were lost, then in place of discard them, I broke manually the exaust tube in the base, and filled them with water. Some white particles reacted with it, and the I got as those old snowing gifts. I sealed the hole with silicone glue. The result is below.
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
Old 22nd January 2019, 12:37 AM   #2
Tubelab_com is offline Tubelab_com  United States
Tubelab_com's Avatar
Back in high school electronics class I would take a tube with the exhaust stem on top, hold it under water and crush the stem with pliers. The vacuum would suck water into the tube. We called these "damper tubes" for obvious reasons, regardless of their original function.
So, what do you do with a damper tube? You connect it up to a power supply and make some steam. The heater is now water cooled (for a while) and can eat more than its original voltage, again for a while. Plate, and grid voltages can be applied, and via electrolysis, make hydrogen and oxygen.
No useful electrical properties were found, except for noise generation, but this requires water replenishment, and was not stable once corrosion and rust set in. Care must be exercised since an internal spark can make a damper tube explode.
These were mostly used to prank a teacher or student, or the manager of the Olson store where I worked.....plug 2 or 3 into each tube tester, then shut the store down for the night at closing time. Manager comes in next morning still drunk from the night before, sees steam shooting from tubes in the tube tester, and goes home to sleep it off.
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Old 22nd January 2019, 10:55 AM   #3
Interesting. I will use them as to decorate my plants. No power to them.
Water filled tubesHide this!Advertise here!
Oil filled capacitor celestar32 Parts 6 3rd April 2016 06:31 AM
Sand filled 2 way 1fspd Multi-Way 5 21st March 2012 04:26 PM
Water cooling Power Tubes thedoci Tubes / Valves 30 14th March 2012 09:29 PM
oil filled capacitor jaudio Parts 5 11th November 2006 10:36 PM
Water cooled plate on ebay (possible water cooled amp application) BrianGT Parts 1 27th May 2002 03:19 PM
Copyright ©1999-2019 diyAudio
