Different Names for Electronic Components
Hi All,
I came up with new names for some electronic components.
Here we go:
Rotmeter, a bad potmeter.
Flakeistor, a resistor that is all over the place.
Fakeistor, a zero Ohm resistor
Desistor, a resistor that can`t make up its mind.
Insistor, a resistor that doesn't want to burn.
Bafenser, a exploding condenser.
A coil and a resistor in parallel, a reductor
Please feel free to find more names,
Best regards, Veeren
I can only manage one:
Flakey - a duff keyboard switch
The rest are different descriptions for components, so slightly off-topic:
damper diode - diode developed in Atlantis
flyback diode - diode with wings
torx - a screw that says it'll screw you
Hall Effect Device - delay for rear speakers
Reed switch - emergency surgery for the Saxophone
Micro-controller - a petite wife
Photomultiplier - photo printing lab
Mercury arc rectifier - orbit corrector for planet 1
Trim pot - potentiometer that exercises regularly
Are these cringeworthy enough? :sorry:
Deadphones - bargain store specials!
Tantrum capacitor - may refuse to store a charge
Balloon - poorly designed balun
Bandana lead - tied up banana lead
Splutter - noisy signal splitter
Stopper motor - converts electricity into zero motion
Hot sink - inefficient heat sink
Boggle switch - off when on
USB flush drive - my data has gone down the toilet!
Yogi - an antenna that's a bear to align
Prototype bored - time this project was brought to a conclusion!
These words can't be translated from my language:
diófa (nut tree) - from "dióda" (diode)
ellenállat (contra animal) - from "ellenállás" (resistor)
kondi - from "kondenzátor" (capacitor)
trafó - from "transzformátor" (transformer)
tranyó - from tranzisztor (transistor)
tekrenc - from tekercs (coil)
poti - from potenciometer (variable resistor)
and so on
