The Lounge A place to talk about almost anything but politics and religion.
Speaker Cable
Speaker Cable
Old 11th November 2018, 05:52 PM   #131
DSP_Geek is offline DSP_Geek  Canada
Originally Posted by scottjoplin View Post
There are coaxial speaker cables. There are transparent line level coaxes, can you see where I'm going with this?.........
Sommer makes some dandy speaker-level coaxial cable under the Magellan name, with 2x2.5 mm^2, 2x4.0mm^2, and 2x6.0mm^2 equivalent thicknesses. I like coax because it has minimal series inductance, and in RF-noisy environments you have less junk getting back to the feedback loop.
https://shop.sommercable.com/en/Cabl...425-0201F.html
https://shop.sommercable.com/en/Cabl...-440-0201.html
https://shop.sommercable.com/en/Cabl...460-0201F.html
Old 23rd November 2018, 10:23 AM   #132
PMA is offline PMA  Europe
PMA's Avatar
DON'T PANIC!!
I'm after suggestions based on aesthetics and practicality please.....
My speakers get moved around a lot, most of the time they are in the middle of my room. The floor is cork tiles. I want a very flexible cable that will stand being moved a lot and lie flat without complaining, and that will also blend with the floor colour to a degree. I like the look of this 3 Core Braided Antique Gold Individually Twisted 0.75mm PLU21134 but am open to all suggestions/advice. Thanks.
2 x 4mm2 twin litz wire.
Old 23rd November 2018, 10:54 AM   #133
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
Thanks for the latest suggestions. As remarked a little earlier, my requirements regards aesthetics have relaxed somewhat, the only place now where the practicalities are still an issue is where they run across the doorway. At the moment the four separate wires are lying side by side taped to the floor, I'm planning to to cover them with some kind of threshold strip, the thinner the better, if anyone has any suggestions I would be grateful.
Woofer Assisted Wideband is the New Testament renounce the anachronistic acronym FAST
Old 23rd November 2018, 11:07 AM   #134
PMA's Avatar
How about this? Seriously, think about Foucault currents!!
Old 10th January 2019, 08:53 PM   #135
WaVeInFoRm is offline WaVeInFoRm
Rugs have there uses..
Old 15th January 2019, 09:44 AM   #136
KaffiMann is offline KaffiMann  Norway
Fanatic
KaffiMann's Avatar
Speaker Cable
You know, they have these nice alu profiles intended for that purpose. Many different types pending on your needs, and the cable will be well protected even if you drop something heavy on them.
Old 15th January 2019, 04:31 PM   #137
Have you looked at seam binders? You'd have to rout a groove in the bottom for the cables, assuming reasonably sized wires, but once that's done it should be both functional and attractive. Should you decide to move, getting the cable out could be interesting so I'd advise screws instead of glue.
Old 15th January 2019, 04:57 PM   #138
Yes, thank you, those appear to be what I meant by threshold strip?
Old 16th January 2019, 05:46 AM   #139
More or less. Threshold strip can cover different heights, say from carpet to tiles, whereas seam binders begin and end at the same height. They seem intended to match two different wooden floors on either side of a doorway, for example.
Speaker CableHide this!Advertise here!
what to consider when you have 500ft of speaker cable how to deal cable capacitance? rhythmsandy Solid State 19 12th August 2014 01:01 PM
Transforming HT Magic Ref Power Cable to speaker cable Kamloopsalman Construction Tips 3 17th July 2012 05:06 AM
Copyright ©1999-2019 diyAudio
