The Lounge A place to talk about almost anything but politics and religion.
John Curl's Blowtorch preamplifier part III
Closed Thread
Old 7th January 2020, 06:57 PM   #34501
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
Old 7th January 2020, 06:59 PM   #34502
jneutron is offline jneutron  United States
jneutron's Avatar
Originally Posted by KSTR View Post
Adobe Addition's resampling filter, 192k-->44.1k-->192k, highest quality... a rather long FIR, suspposedly.
Do you see a "frequency shift" in the red trace as well? If so, you don't understand the peak of the 5x20 spectrum doesn't neccessarily coincide with the carrier when a bit of non-flat EQ is present (Bu2@19kHz, in this case), which is what happened with Hans' filter.
That is exactly why I mentioned moving the graph to provide more detail in that exact area of the spectra.
"Rather long FIR supposedly"? Is there any way to find out? Do they give the user the option of FIR length? That would make it rather easy to see if that is why Han's frequencies were so different.
Besides, filtering can *never* change a frequency, basic knowledge....
Yah, I've heard that before. You are telling the wrong guy that. Go back and look at Han's time display and tell me the two frequencies are the same.
Do you have a better explanation as to why he shows two frequencies? I'm all ears.
Jn
I hate all these smart gadgets..I refuse to buy things that are smarter than me. I've made a list of those things... Cabbage just made the list.
Old 7th January 2020, 07:03 PM   #34503
jneutron's Avatar
Originally Posted by scott wurcer View Post
I like to think of Gibbs as the ghost of the images removed.
I absolutely agree. And your difference plot really shows where the action occurs.
Jn
Old 7th January 2020, 07:06 PM   #34504
jneutron's Avatar
Originally Posted by Hans Polak View Post
In this thread you have to prove everything that you mention to prevent that nonsense is generally being accepted.
Here are two square waves in two amplitudes fed to the same Fir filter that I used earlier, in this case having amplitudes of resp. 1.0 Volt and 0.3 Volt.
After being processed by the Fir filter, I have multiplied the 0.3 Volt filtered version by 10/3.
And guess what, results are exactly on top of each other, proving that ringing has nothing to do with limited slew rate or whatever but only with the transfer properties of the used filter.
Hans
Attachment 807459
All you have done is show that the ringing scales with the slew rate (and height). This is exactly as expected, no surprise. It would be odd if it didn't.
What you need to address is your earlier plots showing a change in frequency after you put it through your filter. That was a totally unexpected outcome.
Oh, thank you for your efforts,,also KSTR, thank you.
Jn
Oh, sorry. If you would, could you please overlay the blue and green waveforms from your earlier post simultaneous in time. Since the frequencies are different, perhaps line up the first zero crossings. Thank you.
Tomorrow I'll make two copies of the plot, use a pair of scissors and some scotch tape, a couple chicken scratches mimicking actual handwriting... scan to jpeg, voila..
Edit: KSTR, if you don't mind, would you do the exact same thing with your software? If you do not support a carrier frequency shift, we have to assume it was something in Han's software package.
Old 7th January 2020, 07:13 PM   #34505
syn08 is offline syn08  Canada
syn08's Avatar
That's incorrect. Only some have to prove everything, even the signal processing 101, others do not consider carrying the same burden. They are free to spew whatever they dreamed last night about.
Old 7th January 2020, 07:25 PM   #34506
syn08's Avatar
Originally Posted by Tournesol View Post
Perhaps the dust surrounding the old EEs protects their 5 CDs from the invasion of molds which seem to appreciate the metal layer of CDs even more than the coating of photographic lenses?
Make that 6 . Attached is about 1/3 of my DVD/CD collection (of 20+ years), in storage, the rest is "active". Never had a dang of a problem with mold or anything else, they are all as good as in the first day. And yes, I saw/listen them all.
Old 7th January 2020, 07:31 PM   #34507
jneutron's Avatar
Why two copies of front to back? Did one get moldy?
Old 7th January 2020, 07:35 PM   #34508
rsavas is offline rsavas  Canada
Maybe Mr. T is storing the disks in a place where one stores their wine perhaps or in the kitchen where humidity is higher? I have never had a mouldy disk or LP either, I have them all in my basement too, it can get humid in the summer time but I do turn on the de-humidifier when it gets too high.
If you leave out some 20-20-20 water soluble fertilizer, exposed to air, when it turns to liquid, it is time to turn on the de-humidifier. Grow-op experience I have a Honeywell humidiy sensor and Atmel xmega code for you if that works better for you.
Old 7th January 2020, 07:37 PM   #34509
elektroj is offline elektroj  Europe
For those interested..
One can download a demo of this plugin for his DAW software and play with all kinds of filter types and lenghts.
DMG Audio : Products : EQuilibrium
Reading user manual is a must.
Old 7th January 2020, 07:38 PM   #34510
Tournesol is offline Tournesol  Belgium
Banned
You should defragment your shelves.
You listen to your CDs with which oscilloscope?
Closed Thread
John Curl's Blowtorch preamplifier part IIIHide this!Advertise here!
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
