The Lounge A place to talk about almost anything but politics and religion.
John Curl's Blowtorch preamplifier part III
Old 13th November 2019, 09:47 PM   #30611
Tournesol is offline Tournesol  Belgium
Tournesol's Avatar
I am building a rocket in my garden, in order to board with some friends to the moon.
I take advantage of the presence of so many EE101 graduated experts here to ask 3 questions:
- What weld should I use for the components of my navigation system ?
(The round trip will only last a few days.)
- The presence of this layer of Rhodium under the thin layer of gold on my printed boards may-it affect the intelligibility of communications with the control room ?
- Is the presence of pieces of hair cut in 1000 likely to cause malfunctions with the connectors?
Yours faithfully,
Tryphon Tournesol
Old 13th November 2019, 09:50 PM   #30612
auplater is offline auplater  United States
auplater's Avatar
Default Rh
Originally Posted by Chris Hornbeck View Post
What's the story on rhodium? It was all the rage in the 1990's.
Much thanks,
Chris
Rhodium... looks great on paper... ~ 1/2 the density of gold, platinum, iridium... one of the lighter noble metals, so when plated goes twice as far per unit area. Still very expensive, tho, often quite a bit higher than gold.
Way back in the 1960's Ted Kozul & Baytron set the standard for high quality commercial microwave waveguides, couplers, circulators, and such, made from silver with a rhodium flash to stop corrosion. These components are still being used around the world, and had a robust, almost gem like quality to them. Niche market.
Problem is, rhodium is difficult to dissolve in most anything, so producing and controlling a usable electrolyte to plate from is difficult. Because of its high cost, not much demand for coatings thicker than 1/4 micron or so exist (mainly jewelry as a coating over white gold) so low concentration flash coatings were about all that existed. Plus the baths tended to be unstable, and the coatings got rough and grainy at any appreciable thickness.
Bottom line, unless needed for hardness or appearance, gold deposition was / is cheaper, more versatile, and can be deposited with many different properties optimized for its use. The rhodium craze (in the audio industry) was a marketing tool to raise the sell point of whatever was being coated
"I've forgotten more than I care to remember" The Last Conspirators
Old 13th November 2019, 10:45 PM   #30613
billshurv is offline billshurv  United Kingdom
billshurv's Avatar
I'm sure I did see Osmium plated connectors once in the 80s but that may be memory playing tricks with me.
Back in the 90s there was a change in the plating of some RF connectors for low frequency (Coupla GHz levels). Silver plate was causing corrosion problems in the field and the iron content in some nickel plate was causing IMD issues. The suppliers came up with a new formulation with usual trade names but I think were related to the class of Cu-Sn-Zn plating that is often called white bronze and comes with some great names like 'Optalloy'. It was shiny, hard enough for our needs, corrosion resistant and gave the IMD performance we needed. Never seems to have done the crossover into audio. I guess because actual performance doesn't really matter
Old 13th November 2019, 10:49 PM   #30614
scott wurcer is offline scott wurcer  United States
scott wurcer's Avatar
If the moon is made of Wensleydale possibly mars is made of Red Leicester. Please tell us when you find out.
"The way up and the way down are one in the same"
Old 13th November 2019, 10:53 PM   #30615
Bonsai is offline Bonsai  Europe
Bonsai's Avatar
Ahh Tin tin
Old 13th November 2019, 11:31 PM   #30616
mchambin is offline mchambin  France
Rhodium plating: 1974.
I made a computer board pcb that had four 50 pins edge connectors.
Contacts had been rhodium plated.
This board implementing two high speed DMA channels was transferring digital pictures from a meteorology satellite. SMS ( Synchronous Meteorological Satellite ).
Transistor junction temperature is not transistor case temperature.
Old 13th November 2019, 11:42 PM   #30617
Chris Hornbeck is offline Chris Hornbeck  United States
Chris Hornbeck's Avatar
Oh! The cat's eaten it.
"A marveilous newtrality have these things mathematicall and also a strange participation between things supernaturall, immortall, intellectuall, simple and indivisible, and things naturall, mortall, sensible, componded and divisible." - John Dee
Old 14th November 2019, 10:09 AM   #30618
gpauk is offline gpauk  Scotland
gpauk's Avatar
Originally Posted by Bonsai View Post
Ahh Tin tin
Is he RoHS compliant...?
Old 14th November 2019, 10:49 AM   #30619
Tournesol's Avatar
After 2 or 3 glasses of an old GLENDRONACH, everything is RoHS compliant.
Yours faithfully,
Tryphon Tournesol
Old 14th November 2019, 10:50 AM   #30620
lead free solder. Rohs compliance.
Tin Whiskers Are Real and Complex - Maxim
John Curl's Blowtorch preamplifier part IIIHide this!Advertise here!
Copyright ©1999-2019 diyAudio
