The Lounge A place to talk about almost anything but politics and religion.
John Curl's Blowtorch preamplifier part III
Old Today, 05:47 AM   #25251
Terry Demol is offline Terry Demol  Australia
Terry Demol's Avatar
Originally Posted by chris719 View Post
See attached from AK4497 EVM datasheet. Looks like a serious problem...
I'm not sure why anyone takes Rob very seriously in terms of claims. He is marketing his product in that video. He mentions anecdotes like his kids heard changes watching cartoons. The old wife-in-the-kitchen thing.
Attachment 768693Attachment 768694Attachment 768695
My point was, I have always noticed this particular DAC artifact he refers to and newer DAC's appear to be improving. The 4499 is the best I've seen.
T
Old Today, 06:11 AM   #25252
Joe Rasmussen is offline Joe Rasmussen  Australia
Joe Rasmussen's Avatar
Originally Posted by PMA View Post
Such theories are on the same level as a Flat Earth theory, to me.
OK. You will never find unless you see. I suggest you tell Hans van Maanen that his amplifiers are rubbish, I will keep out of the firing line. Duck!
"Elsinore Project" DIY Speaker System
- "Don't take anything I say as an affirmation, but as a question." Niels Bohr [i.e. be humble]
Old Today, 06:34 AM   #25253
PMA is offline PMA  Europe
PMA's Avatar
OK Joe, this is your "devil" - I am able to setup such measurement very quickly. This is a distortion of speaker current, speaker driven by a fine low distortion class AB amplifier. The output stage is in A to AB (B) transition zone. Idle current 100mA. 1 pair of output devices. See the distortion level. Any high orders?? I apologize for some mains spectral lines, the setup uses 2 x 10m cables from my lab room to the listening room, so the loops are unavoidable.
Yes I am stating that if there are high order distortions the amp is rubbish. However, Ohm's law is valid and if the impedance would have gross and strange non-linearities, they will reflect in speaker current, regardless it is class A or class B. It just must not be a rubbish.
Old Today, 07:03 AM   #25254
KSTR is offline KSTR  Germany
KSTR's Avatar
Originally Posted by mmerrill99 View Post
That is what I'm trying to find - a better test to expose NFM with the idea of a multitone test signal that varies but perhaps this is the totally wrong direction?
I managed to create a quasi-dynamic multitone by using two adjacent bins per frequency rather than one. This gives a beating of the frequency, its level drops to zero one time within a block of samples, the beat frequency is the bin width. I had to use a larger base multiplier (11 instead of 7) so that the IM components have enough space**) around them as they become wider, too. With some artificial 2nd and 3rd order added, the IM components can be up to 6 bins wide.
With phases all set to zero the waveform looks like a normal multitone which is amplitude modulated as a whole whereas with random phase each frequency has its individual zero amplitude point and it sounds like that, a detuned pipe organ chord which each note swelling up and down at a slow rate at different points in time.
**) For NFM we have to look at the spaces, not the IM components (which are there even if the distortion is fully static). And compare the noise floor in those spaces with the noise floor of a simpler signal, or silence. I tried to do this with my RME Adi-2 Pro in loopback, but alas, no difference found.
I also tried to isolate that obscure "state variable settling" with a variety of time domain tests... again to no avail as of yet...
John Curl's Blowtorch preamplifier part IIIHide this!Advertise here!
Copyright ©1999-2019 diyAudio
