The Lounge A place to talk about almost anything but politics and religion.
John Curl's Blowtorch preamplifier part III
Closed Thread
Old 4th June 2019, 06:38 PM   #21011
mountainman bob is offline mountainman bob  United States
mountainman bob's Avatar
Originally Posted by scottjoplin View Post
Yes, similarly having them out in the room creates more depth
You wanna talk depth? ....look at this screwy positioning, it’s got the real amphitheater depth!
Just a temporary thing till I get my cabinetry done for the entertainment center.
File Type: jpg D9EDAA53-BAE5-4798-A5D2-18469C92CDB4.jpg (412.7 KB, 147 views)
Old 4th June 2019, 06:39 PM   #21012
Jakob2 is offline Jakob2  Germany
Originally Posted by syn08 View Post
Except for insulting everybody’s intelligence and basic common sense. Happens that “close minded” rely on intelligence and common sense.
Seems to be a different definition of the terms "close-minded" and "open-minded" .........
Old 4th June 2019, 06:51 PM   #21013
PMA is offline PMA  Europe
PMA's Avatar
Originally Posted by jneutron View Post
Been there, did that. My discussion is informed by experience.
Jn
Would you share your data, results? As you know, I don't care much about debates.
Old 4th June 2019, 06:54 PM   #21014
Originally Posted by Bonsai View Post
So what you are saying is that tests that fell below the 50% correct threshold are basically taken as the threshold. Ok - makes sense to me - thanks
No, that is a misunderstanding. The threshold is usually defined as the point where 50% of the responses (to the experimental task) are correct.
A series of tests is considered to be a probabilistic experiment; humans aren´t machines, variables aren´t constant over time and so on.
So a series of tests will give results distributed around the real (assumed to be fixed but unknow) value of the 50% of correct responses level. The average is a good estimator (converging to the real value) for the mean.
I´ll try to come back with some further explanations tomorrow or the day after.
Old 4th June 2019, 06:59 PM   #21015
jneutron is offline jneutron  United States
jneutron's Avatar
Again, been there did that. The problem is, some others with a bee up their bonnett will perform the tests badly using poor test methodology without understanding so as to try and prove themselves right. Pretty much what you did.
I have no desire to spoon feed you, as you won't learn that way.
Most important here is critical thinking skills.
Edit: and that is not meant as an insult, most people when forced out of their comfort zone w/r to knowledge, tent to stumble a bit.
Jn
I hate all these smart gadgets..I refuse to buy things that are smarter than me. I've made a list of those things... Cabbage just made the list.
Old 4th June 2019, 07:10 PM   #21016
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
It seems most here aren't aware of that? So, as someone said earlier, what's really going on here?
Old 4th June 2019, 07:32 PM   #21017
Interaural time difference - Wikipedia He used "in the wild" differently earlier in the discussion IIRC, to mean.....errr....in the wild
That’s kinda what I thought but trying not to scrutinize !
Old 4th June 2019, 07:34 PM   #21018
scott wurcer is offline scott wurcer  United States
scott wurcer's Avatar
I guess any software they used would have to delay via the digital samples? I wonder if they verified that what they requesting of the unit actually happened as they expected?
jn
You can do sub-sample shift via FIR. http://home.agh.edu.pl/~turcza/sr/Sp...it%20Delay.pdf
"The way up and the way down are one in the same"
Old 4th June 2019, 07:34 PM   #21019
Folks, it would be great if you could find a way back to a less hostile/agressive style of communication.
Old 4th June 2019, 07:37 PM   #21020
jneutron's Avatar
The entire audio chain is comprised of some very complicated stuff. Electronics which many here are excellent at, speakers...same deal, sources, testing, etc.
But there is a disconnect. A virtual soundstage requires more than just low distortion electronics. It is important to understand what compromises the virtual image.
Without understanding what is needed how does one control it?
Over the years I've tested the stability of both lateralization as well as localization on myself only. And in that process I've had to do a lot of research.
We have quite a few here that are very knowledgeable in human hearing capabilities, it is important that all discuss.
Jn
Closed Thread
John Curl's Blowtorch preamplifier part IIIHide this!Advertise here!
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
