The Lounge A place to talk about almost anything but politics and religion.
John Curl's Blowtorch preamplifier part III
John Curl's Blowtorch preamplifier part III Please consider donating to help us continue to serve you.
Closed Thread
Old 26th May 2019, 08:34 AM   #19991
chris719 is offline chris719  United States
The fact is, you have no clue what you are doing.
Now that we have established that you have only heard this supposed phenomenon and then invented some crackpot theory using words you do not understand, we can all move on.
This could be easily measured, if it were true.
Old 26th May 2019, 08:44 AM   #19992
john curl is offline john curl  United States
john curl's Avatar
Yes Dan, sometimes the only way we can tell things apart is by LISTENING. Cable directionality seems to be one of these characteristics.
"Condemnation without Examination is Prejudice"
Old 26th May 2019, 09:02 AM   #19993
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
Like the brightness of silver wires John? BTW, T very politely asked you a question about that, do you have a reply you feel you can share?
Old 26th May 2019, 09:08 AM   #19994
Zung is online now Zung  Switzerland
I'm confused. This is an audio forum, right? Isn't audio about listening? Or is it about reading numbers on a display?
Old 26th May 2019, 09:11 AM   #19995
Here, it's about reading what people say (or not)
Old 26th May 2019, 09:15 AM   #19996
Max Headroom is offline Max Headroom  Australia
Banned
Location: West Australia, near to the beach, natural ambient sounds mostly.
Originally Posted by Markw4 View Post
Okay, suppose you take a wire, fold it in half, and cut at the fold. Now there are 2 wires each pointing in the, shall we say, opposite noise direction. Solder them together like that in parallel. Does the directionality of the parallel structure then cancel out?
Yes, and this is one feature of the TS/GC loopback cable used. Goop makes directional effects of standard cables more obvious, and also makes more obvious that the TS/GC cable is indeed essentially non directional. Fold in half and cut is how I 'discovered' directional effect in coax/shielded cable hardwired to my TT....this led me on a merry chase until I was shown the effect as I described in a previous post.
Dan.
Old 26th May 2019, 09:17 AM   #19997
Originally Posted by Max Headroom View Post
Goop
Dan, I take it all back, congratulations on your partnership with Gwyneth Paltrow
Old 26th May 2019, 09:22 AM   #19998
Banned
Yes, try listening to some silver cable and you may 'discover' something for yourself.
I now have loopback recordings that illustrate this 'brightness', who cares what 'theory' says when the facts are clear.
Dan.
Old 26th May 2019, 09:27 AM   #19999
indra1 is offline indra1  Indonesia
... My determination of directional characteristic is by swapping cable directions and listening....the sound changes follow cable changes, and both channel cables exhibit the same effects, ie there is nothing wrong with the interconnects....
Sorry Dan, wrong assertion. The interconnects may be accepted as normal, but there is at least something wrong with them, most probably due to the crappy RCA connectors, try BNC or better direct soldering.
Originally Posted by chris719 View Post
... This could be easily measured, if it were true.
Perhaps not so easy for you and I, but I'm quite confident that Pavel can.
Old 26th May 2019, 09:31 AM   #20000
Banned
The fact is, you have no clue what you are doing. Now that we have established that you have only heard this supposed phenomenon and then invented some crackpot theory using words you do not understand, we can all move on. This could be easily measured, if it were true.
You have no real clue about audio or the results that I am achieving. So a couple of files were bunky but not fatally, so what ?. You have not indicated that you have auditioned any of the other loopback recordings, suggest a track you know and like and I will process it for you. My next round of loopback recordings should capture directional effects and stand as proofs. Then we can debate the causes, in the meantime you could try reversing one interconnect and try the experiment for yourself, that is if you have a stereo worth listening to (IIRC you have a little Bose satellite system, is that right ?).
Dan.
Closed Thread
John Curl's Blowtorch preamplifier part IIIHide this!Advertise here!
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
