The Lounge A place to talk about almost anything but politics and religion.
No RF gear here?
No RF gear here?
Old 11th July 2019, 03:50 PM   #571
w5jag is online now w5jag  United States
I hooked up the cheap eBay AD9850 DDS module last night.
It comes with nothing, no instructions, no pigtails, no encoder, so I had to spend a bit of time hooking that stuff up, which kept me from being able to spend much time playing with it.
I don't know what the correct voltage is, but this one is best at about 8 VDC. Below that, you get output, but can't see the display. Above that, the display will fade after a minute or so.
These are advertised as 0-55 MHz, but this one has only a 125 MHz clock chip, and the useful upper limit maxes out at about 41 MHz, or so. So, it should really be advertised as 0 - 40 Mhz.
This one has kind of an interesting feature, in that as the the encoder is spun faster, the tuning rate advances, much like a real radio. I installed a non detent encoder on this ( because it is what I had in stock ) so it has a nice feel, but for mobile use, I think a detent encoder will be a better choice.
There is an RF board on the back of the DDS board. This one has a non descript SOT-89 chip that just says "RF" on it. THe gain is set wrong for frequencies around 20 MHz, as shown in the FFT. There is a jumper that can be removed to turn the gain down in this range, but I have not played with that, yet.
FFT's attached in the 5 MHz and 23 MHz range ( low and high side injection for converting 14 MHz to 9 MHz ) and you can see that the 23 MHz signal is about ten fold stronger than the 5 Mhz side, and horribly distorted as a result. 5.X Mhz looks good, only harmonics of the fundamental show up on the FFT.
Win W5JAG
Old 12th July 2019, 12:09 PM   #572
jackinnj is online now jackinnj  United States
jackinnj's Avatar
No RF gear here?
Originally Posted by Tubelab_com View Post
We haven't had that kind of standing water here, just newly formed rivers running where streets used to be. Not much of it has made even the local TV news, but there are several videos on Facebook, one with an unoccupied car being swept down the street by the water.
The creek behind our house runs from the Ohio rive,r past us, then all the way into Pennsylvania (20 miles). The sun can be shining here, but a strong storm or snow melt 10 miles to our east can flood our backyard. So far that hasn't happened in this storm series.
George - you would find McCulloughs book “Pioneers” to be very interesting - your neck of the woods from the 1770s to 1850’s.
Old 12th July 2019, 03:59 PM   #573
Disabled the gain compensation for the 20 something MHz band.
Looks better. I'll use the RP to look at it when I get a chance.
Win W5JAG
Old 16th July 2019, 01:13 PM   #574
https://apolloinrealtime.org
Win W5JAG
Old 16th July 2019, 01:19 PM   #575
gpauk is offline gpauk  Scotland
gpauk's Avatar
Great link - thanks!
Old 16th July 2019, 01:30 PM   #576
jackinnj's Avatar
No RF gear here?
Originally Posted by w5jag View Post
Interesting -- I remember going outside and just staring into the sky after this was over.
I don't think we got a color TV until 10 years afterward!
Old 16th July 2019, 02:24 PM   #577
Unified S-band - Wikipedia
References 1 and 4 are pretty interesting reading. The command module ran a 20 watt carrier.
I recall reading that some Ham was able to pick up one of the lunar backpacks with a giant corner reflector antenna - they were in the UHF aero band - 273 something MHz, IIRC. Pretty good DX.
edit: W4EJA
Eavesdropping on Apollo 11
Win W5JAG
Old 16th July 2019, 02:37 PM   #578
Tubelab_com is offline Tubelab_com  United States
Tubelab_com's Avatar
I had the only color TV in the neighborhood. It was a 1957 vintage Emerson (RCA built) that I had rebuilt with a 60's vintage all glass CRT. My bedroom was the old garage with some carpet (bare concrete, bare feet, and hot chassis electronics DON"T mix). There were 30 or so people stuffed into it in the middle of the night to watch that first live color broadcast from the moon.
There was an older ham who had built a large dish antenna with lunar tracking to receive the LEM to Earth transmissions. He had recorded them to analog tape and he would play them to an audience in a forum meeting at the Dayton hamfest in the early 2000's. His completely independent transcription of the events helped dispel some of the "it never happened" conspiracies. Don't know what happened to it all when he passed.
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Old 16th July 2019, 05:42 PM   #579
gpauk's Avatar
Yes, I also knew someone who also recorded a lot of the transmissions. Which ought to have dealt with the "fake news" brigade - but the always just come up with some other nonsense. You can't win!
Old 16th July 2019, 06:12 PM   #580
gerhard is offline gerhard  Germany
gerhard's Avatar
We in southern Germany can stare tonight, too. 2/3 Lunar eclipse.
BTW. I have not forgotten you. I have built up the first 3 pieces; the post
amplifier was oscillating. That was coupling over the analog mux, I could
fix that with isolation resistors. Expect mail early next week.
Gerhard
"That's right!" shouted Vroomfondel, "we demand rigidly defined areas of doubt and uncertainty!" "We don't demand solid facts! What we demand is a total absence of solid facts. I demand that I may or may not be Vroomfondel!"
No RF gear here?Hide this!Advertise here!
Where to get audio gear? kuer Everything Else 0 18th April 2015 06:38 AM
Available Gear GrampasStuff Swap Meet 0 10th March 2011 07:22 PM
used gear site Jim Leach Everything Else 0 2nd March 2011 07:43 PM
Laser Pickup´s M52103FP RF-Amp instead of older CX20109 RF-Amp Salar Digital Source 2 25th July 2010 05:44 PM
I am looking for the following gear ....... musicprodusa Instruments and Amps 0 26th November 2006 08:22 AM
Copyright ©1999-2019 diyAudio
